what octane would i have to use for this setup
Old Apr 30, 2005 | 05:08 PM
racekar's Avatar
Default what octane would i have to use for this setup
im planning on getting a used gsr integra and putting a conservative greddy turbo would i still be ok with 91 octane???
thanks
Old Apr 30, 2005 | 05:16 PM
StolenTeg's Avatar
Default Re: what octane would i have to use for this setup (racekar)
You pump the highest gas you have around, the higher the octane the more power you will be able to make. im using 93 for my greddy kit and have no problem paying 2.50 per gallon, it all worth it to me in the end, if you spend the money to go turbo then you shouldnt try to save a buck or 2 at the pump.
Old Apr 30, 2005 | 05:19 PM
adseguy's Avatar
Default Re: what octane would i have to use for this setup (StolenTeg)
you don't make more power with higher octane, you just help prevent detonation. I know it's picky
Old Apr 30, 2005 | 09:14 PM
racekar's Avatar
does it matter if i turbo a LS or gsr in terms of 91 octane?
does a gsr turbo require higher octane? just trying to decide what my next street/track will be.
im kind of set on an integra or 240
i want to go turbo this time but want to know what kind of setup i can get away with with just 91 octane
Old Apr 30, 2005 | 09:25 PM
xxtavixx's Avatar
Default Re: what octane would i have to use for this setup (adseguy)
adseguy is correct on this one. You want to run the higher octane simply to prevent any form of knock/detonation. A car will feel faster because with the higher octane the ECU is not going into limp mode because the knock sensor is picking up small harmonics. I'm not familiar with Hondas, so I am assuming the ECU has the ability to retard. I would firmly suggest running the highest octane on pump gas you can find.
Old Apr 30, 2005 | 09:46 PM
racekar's Avatar
for you turbo guys with experience with integras. would the gsr or ls engine be safer on 91 octane?
thanks
Old Apr 30, 2005 | 11:34 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">You pump the highest gas you have around</TD></TR></TABLE>
what if the highest in my area is 110 octane? seriously we have straight race gas at the pump here.
lol, i use 93 and sometimes put some octane booster in..
Old May 1, 2005 | 01:00 AM
integlspwr2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar &raquo;</TD></TR><TR><TD CLASS="quote">im planning on getting a used gsr integra and putting a conservative greddy turbo would i still be ok with 91 octane???
thanks</TD></TR></TABLE>
87 should be okay..
Old May 1, 2005 | 08:21 AM
adseguy's Avatar
Default Re: (racekar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar &raquo;</TD></TR><TR><TD CLASS="quote">for you turbo guys with experience with integras. would the gsr or ls engine be safer on 91 octane?
the higher the compression the more chance of detonation so the higher the octane you need to put in it. the LS will always be safer on 91 octane, but a properly tuned GSR will be fine on 91 as well.
Old May 1, 2005 | 02:28 PM
StolenTeg's Avatar
Default Re: (adseguy)
Higher octance=more timing=more power?
Old May 1, 2005 | 03:42 PM
Da K00l Aid Mayun's Avatar
Default Re: (StolenTeg)
From my understanding, the higher octane, it allows you to run more boost. So depending on how much boost you want to run, that will determine what octane you should use.
Old May 1, 2005 | 04:06 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">Higher octance=more timing=more power?</TD></TR></TABLE>
Safer power. In a car running knock sensor could be more power.
JTTeG_X
May 19, 2009 08:08 PM
eg:R
Nov 27, 2007 06:15 PM
tsdenny
Aug 21, 2004 01:55 PM
HondaGuy02
May 6, 2004 11:37 AM
jonoknut
Mar 9, 2003 04:40 PM
