location of oil restrictor??????
Old Apr 29, 2005 | 05:20 AM
black98gsr-t's Avatar
Default location of oil restrictor??????
just want to know where to put the oil restrictor: on the turbo or on the engine. i know i should just use a -3 line and fittings but i already have all the stuff needed to use a -4 line... i filled one of the fittings and drilled it to a smaller size... just not sure if putting it on the engine is the same as on the turbo? any info would be great, and yes i did search ( oil restrictor,, oil feed line, oil line, restrictor) if you know of another post please link it.......
Old Apr 29, 2005 | 05:22 AM
94lsboost's Avatar
Default Re: location of oil restrictor?????? (black98gsr-t)
mine is on the turbo, I have no knowledge of them on the engine tho so I can't compare.
Old Apr 29, 2005 | 06:03 AM
HiProfile's Avatar
Default Re: location of oil restrictor?????? (94lsboost)
I was thinking about this yesterday, oddly enough. A restrictor on the engine will clean up your setup, as well as allow a steady flow into the turbo. A restrictor on the turbo will shoot the oil directly onto the shaft, which might be better. If it was watercooled too, it probably wouldn't matter, but oilcooled-only, I'd go with the restrictor on the block.
Old Apr 29, 2005 | 08:24 AM
redzcstandardhatch's Avatar
something different
you can pretty much put it wherever you want....i have two oil lines, and it goes between those two...as does my oil pressure sender.
Old Apr 29, 2005 | 12:20 PM
mid-day bump for any more thoughts......
Old May 3, 2005 | 05:57 AM
ham's Avatar
ham
what kind of pressure (psi) are you running to the turbo?
Old May 3, 2005 | 08:04 AM
something different
Default Re: location of oil restrictor?????? (ham)
i run 10 psi to the turbo at idle (warm)
and abour 35 at 4000 rpms...., 40 or redlined.
Old May 12, 2005 | 09:01 AM
staticchmbr's Avatar
Default Re: location of oil restrictor?????? (redzcstandardhatch)
where can you buy oil restrictors at?
Old May 22, 2005 | 06:17 AM
scartail's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">i run 10 psi to the turbo at idle (warm)
and abour 35 at 4000 rpms...., 40 or redlined. </TD></TR></TABLE>
What sizes are your oil lines?
Old May 22, 2005 | 06:45 AM
johnmay19's Avatar
Default Re: location of oil restrictor?????? (staticchmbr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticchmbr &raquo;</TD></TR><TR><TD CLASS="quote">where can you buy oil restrictors at?</TD></TR></TABLE>
Here you go. http://www.atpturbo.com/Mercha...e=OIL
blk96coup
Jul 28, 2008 11:33 AM
jdm2ner
May 15, 2005 12:52 AM
SiDonny
Apr 1, 2005 08:47 AM
jacob_kohler
Sep 17, 2004 12:44 PM
revhigh96
Sep 6, 2003 08:19 PM
