Hondata and MSD SCI
Old Apr 29, 2005 | 10:34 AM
pcguy760's Avatar
Default Hondata and MSD SCI
Hi,
I am wondering if I have the Hondata ECU and the S200 will I need to or can I still use my MSD Ignition box?
Thanks.
Old Apr 29, 2005 | 11:43 AM
Ben Huynh's Avatar
Default Re: Hondata and MSD SCI (pcguy760)
Yea you can still use it.
Old Apr 29, 2005 | 10:15 PM
pcguy760's Avatar
Default Re: Hondata and MSD SCI (ben@importparts.com)
What made me ask this question, is that I noticed that the MSD controls the spark directly so does this mean that the ECU will not have any control of the rev limiter? That means no rev limiter?
Old Apr 29, 2005 | 10:46 PM
SFWD 1934's Avatar
Do you have the silver box, or the blue box? Because the newer blue boxes for the SCI, DO NOT have an over all rev limiter. The blue SCI boxes are identical to the red Digital 6 boxes with the exception that the red Digital 6 boxes DO have the over all limiter.
Regardless, you can use either the MSD one (if so equipped) or the Hondata.
Jason
Old Apr 29, 2005 | 10:56 PM
pcguy760's Avatar
Hey there, yeah I have the Silver MSD SCI 6300 box. So will this work with the Hondata ECU?
What confuses me though, is that I read that the Hondata ECU controls the ignition timing for boost BUT since the MSD is controlling the spark / ignition - how does the Hondata operate in that case?
Old Apr 29, 2005 | 11:54 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (pcguy760)
You set the rev limiter in your computer. It has an ignition output that goes to the MSD box. The ignition output on the computer tell the MSD box when to fire. Simple as that. S
Old May 2, 2005 | 09:57 PM
pcguy760's Avatar
Default Re: (Arturbo)
Well I just found out why I was confused lol - well it so happens that Hondata actually uses the fuel cut off for its revlimiter and MSD uses the ignition spark for it's cut off. Makes sense to me lol.
Old May 4, 2005 | 04:56 PM
jdmotorsports's Avatar
msd 6300 has no cutoff. if it did you would have a spot on the front for "pills" to be put in. but the 6320 has the cut off.
MugenSpeclNY
May 4, 2012 11:18 PM
delsol revolution
Jul 31, 2006 04:43 PM
jfoster
Nov 15, 2004 07:11 AM
hondaspeder
Sep 7, 2003 09:00 AM
salt
Sep 30, 2002 01:01 PM
