Finished turbo now need help
So i finished my turbo setup but now when i start the car up it fires right up and idles fine. But everytime i give it gas in gear it wants to stall out. Could this be a fuel problem? I am running 450 injectors i dont know what it is .. i have uberdata as well if someone knows please help
Mhm...tricky one. Are you running any form of fuel control? That could be a problem. I'm not familiar with Hondas, but is it possible that your timing is being pulled too far off course? I would also double check all of the ignition components and gap on the plugs.
Re: (xxtavixx)
I have the 450 injectors and im also running a walbro fuel pump my uberdata was programmed to reconize the injectors? could it be my o2 sensor?
Re: Finished turbo now need help (Treblarefils)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Treblarefils »</TD></TR><TR><TD CLASS="quote">Make sure the injectors are scaled right. Check over install again. It should work if everything is right.</TD></TR></TABLE> How do I go about that?
digitalVinyl
10-25-2006 05:52 AM
