Got turbo. Time for engine build!
Old Apr 28, 2005 | 04:34 PM
hybrid0006's Avatar
Default Got turbo. Time for engine build!
Alright... Well my b16 couldn't handle my 10 psi It was a stock b16a w/ b16a2 head running 10 psi. A ring blew so compression is crap and there is all sorts of smoke coming out the back end. I need to rebuild engine asap.
The Turbo Setup:
Precision SC-34
RC 440cc injectors
Walbro 255hp
UberData (tuned - Speedline)
Tial 38mm WG
TurboXS BOV and BoostController (9.5-10psi)
I am looking for somthing that isn't to insanly priced but can handle 10psi for along time. I need reliability. Any recommedendations?
Old Apr 28, 2005 | 05:14 PM
adseguy's Avatar
Default Re: Got turbo. Time for engine build! (hybrid0006)
how much power where you putting down?
you can rebuild stock if it's under 340whp or so
if you want bigger and you can just get rods and pistons and that'll do you 400+ HP with bigger injectors of course. Check out the sponser sections. They have great package deals
Old Apr 28, 2005 | 05:28 PM
hybrid0006's Avatar
Default Re: Got turbo. Time for engine build! (adseguy)
Well thats the thing... I don't need anymore than like 320whp. I don't know if I should do with expensive aftermarkets parts or just oem parts. Its just that I have put soooo much money into this car already, and its like I gotta keep buying part after part after part. Its crazy. I need to stop spending so much, but I like having a nice car that is pretty quick.
Old Apr 29, 2005 | 03:21 PM
hybrid0006's Avatar
bump
Old Apr 29, 2005 | 03:30 PM
b16sedan's Avatar
https://honda-tech.com/zerothread?id=1181347
800 dollars for Wiseco Pistons and Eagle Rods. It's worth it over stock parts.
Old Apr 30, 2005 | 05:50 PM
hybrid0006's Avatar
Default Re: Got turbo. Time for engine build! (b16sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16sedan &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1181347
800 dollars for Wiseco Pistons and Eagle Rods. It's worth it over stock parts.</TD></TR></TABLE>
Thats expensive for me...
Old Apr 30, 2005 | 07:39 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid0006 &raquo;</TD></TR><TR><TD CLASS="quote">
Thats expensive for me...</TD></TR></TABLE>
then you shouldn't boost your engine if you cant afford to spend &lt;800 bucks to make it reliable....
Old Apr 30, 2005 | 08:37 PM
b16sedan's Avatar
Gee, your stock B16 ringlands blew at 10 psi. You want to continue to run 10 psi. What does this tell us? It tells us you need ATLEAST forged pistons, otherwise you're going to be tearing the motor down again with more busted ringlands, and it's suddenly going to get a lot more expensive than 800 dollars. Save up for 2 more weeks and buy the pistons and rods.
Old May 1, 2005 | 06:22 AM
hybrid0006's Avatar
Well, I was thinking about turning the boost down to like 7 maybe. But I am in school now, so I am basically jobless at the time. That is the problem.
Old May 1, 2005 | 08:53 AM
kabaroo's Avatar
your gunna want bigger injectors too.
Old May 1, 2005 | 10:07 AM
asylumxl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.homemadeturbo.com - palace of the ghetto *** honda tuners
Old May 1, 2005 | 12:14 PM
nonvtecD's Avatar
I would just do a stock rebuild with a thicker headgasket and back off your timing to protect those ringlands. That is if you want to keep it cheap.
Old May 1, 2005 | 01:31 PM
s2kdre's Avatar
Default Re: (nonvtecD)
got to pay to play
Old May 1, 2005 | 02:24 PM
dornon13's Avatar
Default Re: (jdmhonda)
that is a pretty good deal!
Old May 2, 2005 | 02:43 PM
hybrid0006's Avatar
Default Re: (dornon13)
Alright guys, I think I found a deal I am interested in.
Eagle Rods, CP Pistons, Head Gasket, Bearings, and ARP Headstuds for $1000 shipped
Sound good?
Old May 2, 2005 | 06:21 PM
adseguy's Avatar
Default Re: (hybrid0006)
yeah that's a good deal
CP + Eagle = $849
head gasket = $85
ARP head studs = $? ....what like $40??
Bearings= depends, but can get to like $50
so yeah it's an ok deal
Old May 3, 2005 | 06:41 PM
hybrid0006's Avatar
Default Re: (adseguy)
I am considering sleeving my block as well. SO EXPENSIVE. Ha. But it would be damn reliable. Anyone know some cheap prices on sleeving?
kcfoodsci
Aug 18, 2016 08:51 AM
anthony_ek4
Sep 23, 2014 09:36 PM
Pellegrini808
Aug 30, 2013 10:10 PM
deuce_Fc
Apr 23, 2013 07:14 AM
patrickd_21
196
Feb 18, 2009 11:31 AM
