ford t3 downpipe gasket where can i buy one?
WTB: ford t3 5 bolt downpipe gasket. i put a turbo kit on my crx yesterday, and i need a new gasket. this one is leaking pretty bad. i need the ford 5 bolt downpipe gasket, and i called around to different ford dealers, but they dont have them. where can i buy one of these??
the turbo is off of an 86 thunderbird turbocoupe .48/.60 ar t3
Re: ford t3 downpipe gasket where can i buy one? (staticchmbr)
Nobody I know runs a gasket there, including me. Red Permatex gets the job done on my Ford 5-bolt turbine outlet. There's no pressure there, so a gasket isn't needed, just a bit of sealant to keep it from leaking.
Re: ford t3 downpipe gasket where can i buy one? (rmcdaniels)
agreed - I actually don't even use RTV. If your flange surfaces are flat they will not leak. Take the gasket out and bolt 'er up!
Yeah I've had bad luck with the DP bolts backing out when using a gasket. Just bolt it directly to the turbine housing. If it is leaking that much, your DP flange is warped etc.... resurface it (I've done this before with a belt sander, wear gloves!).
pushinlsteg
05-19-2005 08:15 PM
staticchmbr
05-02-2005 10:51 AM
