In need of advice
Old Apr 29, 2005 | 04:59 PM
spoolingb20's Avatar
Default In need of advice cant figure out whats wrong????????????
ALright I just ahd my car tuned three weeks ago and the car was running great in the past 6 months my car has spent about 13 total hours on the dyno for tunning just trying to push max boost and still be reliable. Well then this past saterday i start my car go out for a ride up and down a mountain and my car in thrid gear at around 6500 rpms just stops pulling the car still runs great no other problems at all and its not a complete power loss but i can deff. notice something. It also doesnt seem to happen in any other gear just thrid any suggestions would be great cause i recently moved and have no shops within a couple of hours.
Here is my setup
93 CIVIC DX HATCH TYPE -R YELLOW
MOTOR BOTTOM END
98 Integr gsr botom end
AEBS t-sleeves
CP 9.1 low comp. pistons
Eagle rods
New oil pump, water pump, and timing belt
84 mm turbo head gasket
ARP head studs
TRANSMISSION
96 Integra GSr tranny
Quiffe lsd
Honda mtf
Clutch Master stage 4 clutch
TURBO SETUP
Drag turbo kit with many upgrades
Inline pro turbo manifold
Tail Wastegate
Precision Intercooler 760 hp
Precision sc44 turbo
Greddy turbo timer
Skunk2 intake manifold
FUEL SETUP
Walbro 255 fuel pump
Inline pro fuel rail
Precision 680 injectors
Honda OEM resistor box
AEM FPR
Camp 1320 autlike fuel press guage
EMS
Hondata s200b W/3 setup
Hondata p28 socketed ecu
GM 3 bar amp sensor
SUSPENSION
Integra gsr front and rear disc brakes
RS booster master cycl
4040 prop valve
Brembo rotors
Stainless steel brake lines
Omni-power full coilovers
Full race traction Bars
Modified by spoolingb20 at 3:17 PM 4/30/2005
Old Apr 30, 2005 | 02:17 PM
Default Re: In need of advice cant figure out whats wrong???????????? (spoolingb20)
anyone
Old Apr 30, 2005 | 02:42 PM
cliff666's Avatar
got any blowby? also are u running any type of breather system for it? i seen alot of problems with positive crankcase pressure with a few of my freind's cars that did result in a BIG OUCH hope its nothing major gl
DAprojectTuRtle
Dec 11, 2011 11:22 PM
JDM H2B EK
Nov 15, 2009 03:24 PM
bjones
Dec 15, 2008 02:32 PM
spoolingb20
Jun 6, 2005 09:56 AM
TurboBumblBee
Mar 21, 2005 07:02 PM
