550's work with hondata and 8lbs of boost
i was trying to sell my rc 550's and they dont seem to be selling so i was wndering if they will work with hondata,walbro fuel pump and im only going to be running 8lbs, the spring size.its a built h22,9:1 je pistons,if any of this info is nessesary. a shop near me said that it wont perform the duty cycle or something like that, i just wanted some other opinions. still new to turbo setup, thanks guy
Re: 550's work with hondata and 8lbs of boost (jdmclick8u)
They will be fine... I had rc550s in my lsvtec and it started, idled, and drove fine, just like stock. Also the 550s should be enough for the 8psi you're planning for.
Re: 550's work with hondata and 8lbs of boost (turtle-eg)
Depending on fuel set up (i.e. pump/regulator/rail psi at idle/etc) those should be good for somewhere in the area of 300whp. That will put you at a decent duty cycle.
Jason
Jason
