to where should i clock the middle section??
Old Apr 30, 2005 | 08:10 AM
RACEPAK's Avatar
Default to where should i clock the middle section??
hello everybody.
i neet to rotate the middle section (oil/bearing) of my turbo because now the the outlet flange is facing up.
where would be the most optimal spot to clock it ??
best regards moshik galimidi
Old Apr 30, 2005 | 08:31 AM
b16sedan's Avatar
Default Re: to where should i clock the middle section?? (RACEPAK)
Straight up and down.
Old Apr 30, 2005 | 09:10 AM
EJ1 wilcox's Avatar
Default Re: to where should i clock the middle section?? (b16sedan)
The oil inlet should not be more than 30 degrees off center... straight up and down is the best position...
Old Apr 30, 2005 | 12:53 PM
RACEPAK's Avatar
Default Re: to where should i clock the middle section?? (EJ1 wilcox)
so is it Straight up and down or not more than 30 deg off center ?
i'll try to find somthing about it in the maximum boost book.
Old Apr 30, 2005 | 01:18 PM
thermal's Avatar
Yep. The whole point is a dry bearing sump on the turbo to avoid oil caking which can eventually seize the bearing.
Old Apr 30, 2005 | 02:35 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">so is it Straight up and down or not more than 30 deg off center ?
i'll try to find somthing about it in the maximum boost book.</TD></TR></TABLE>
you will find the same thing in that book. I don't see a reason you cant go perfectly vertical so just do it that way.
Old Apr 30, 2005 | 02:48 PM
RACEPAK's Avatar
Default Re: (thermal)
is that ok? or is it too close to the manifold? do you think that the heat will damage the line?
Old Apr 30, 2005 | 02:59 PM
Bailhatch's Avatar
Default Re: (RACEPAK)
put a 90 or 45 coming out of the turbo and it will be perfect.
Old Apr 30, 2005 | 03:06 PM
RACEPAK's Avatar
Default Re: (Bailhatch)
i dont get it sould i rotate it or not? (i just got the picture as a exapmle.
Old Apr 30, 2005 | 03:11 PM
Bailhatch's Avatar
The drain MUST face down. so spin the middle about 180*. then (assuming the inlet is set up for 1/8"NPT) put that 90* fitting on your turbo pointing tword the front of the car so the feed line loops away from the manifold.
you are taking off the internal WG?
Old Apr 30, 2005 | 03:20 PM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote"> put that 90* fitting on your turbo pointing tword the front of the car so the feed line loops away from the manifold.
ok sure i will spin the middle, but why do i need to use the 90deg fitting? because the heat? i see alot of peoples run the oil lines between the runners.
you are taking off the internal WG?</TD></TR></TABLE>
no i have a plate for it
Old Apr 30, 2005 | 03:28 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">ok sure i will spin the middle, but why do i need to use the 90deg fitting? because the heat? i see alot of peoples run the oil lines between the runners. </TD></TR></TABLE>
Well if you dont use the 90 degree fitting for the oil inlet what else are you going to use it for?
Just set it oil inlet up, oil outlet down, 90 degree fitting in the oil inlet. Then you dont have to worry about heat from the manifold affecting the feed line.
Old Apr 30, 2005 | 03:32 PM
Bailhatch's Avatar
a lot of people are not setting it up as good as it can be then.
Old Apr 30, 2005 | 04:41 PM
adeihl's Avatar
i ran my feed touching my mani for a few months... when i took it apart everything was kosher.
If you are really that concerned, get some aeromotive fire sleeve.. That stuff is the shizzy!!!!
Ir just go with the 90 degree fitting like suggested. Ever consider running a hard line? that is what is on my setup. Functions perfect, looks clean as hell.
good luck!
Andrew
JSPECSIR
Sep 27, 2006 04:58 PM
Gdub00lude
Feb 16, 2006 09:05 AM
PM-Performance
Nov 7, 2005 05:06 PM
2000vsm
Aug 29, 2003 08:08 AM
