Breaking in a turbo? Wtf?
Old Apr 30, 2005 | 08:19 AM
Integra GSR 95's Avatar
Default Breaking in a turbo? Wtf?
I am going to pick my car up tonight from the shop where the turbo was installed. They said the boost is currently set @ 4 psi. I wanted it @ 7 psi. He told me to drive it around for about 1000 miles to break the turbo in and the crank the boost up to 7. Does this **** sound logical? I have never head of it but maybe he's right. Is he?
Old Apr 30, 2005 | 08:36 AM
dasher's Avatar
Default Re: Breaking in a turbo? Wtf? (Integra GSR 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra GSR 95 &raquo;</TD></TR><TR><TD CLASS="quote">I am going to pick my car up tonight from the shop where the turbo was installed. They said the boost is currently set @ 4 psi. I wanted it @ 7 psi. He told me to drive it around for about 1000 miles to break the turbo in and the crank the boost up to 7. Does this **** sound logical? I have never head of it but maybe he's right. Is he?</TD></TR></TABLE>
no...
Old Apr 30, 2005 | 08:45 AM
SOHCmaster's Avatar
turn that s#!t up wtf... Aint no break in process.
Old Apr 30, 2005 | 10:14 AM
G-Phi's Avatar
Default Boost!
Get it tuned first before you turn up the boost and blow your motor!!
Old Apr 30, 2005 | 10:37 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: Boost! (G-Phi)
isnt 7 psi safe for a stock engine?
Old Apr 30, 2005 | 10:40 AM
Treblarefils's Avatar
Default Re: Boost! (benb18a)
7psi with the correct amount of fuel.. 7psi is more than enough to break something. If not enough fuel is there.
Old Apr 30, 2005 | 10:41 AM
Default Re: Boost! (Treblarefils)
most turbo kits will take care of that though, right?
Old Apr 30, 2005 | 11:12 AM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a &raquo;</TD></TR><TR><TD CLASS="quote">most turbo kits will take care of that though, right?</TD></TR></TABLE>
take care of tuning?? no, you have to tune it yoursefl, preferrably an EMS like uberdat or hondata. BTW: Uberdata is the shiznit
BlueShadow's Avatar
If all your stuff just got installed it would make sense to drive it gently the first few hundred miles. Watch for leaks, listen for odd noises and be aware of any weird smells. You can raise the boost up to 7 PSI. But once you have driven it around and nothing leaks, smells, or makes noise then gradually boost it. Do a few pulls in low boost like 2-3 PSI, pull over and recheck the car if you like. Then do some 4-5 PSI pulls, check the car. Then if you are feeling brave enough, do one WOT pull and closely watch your boost gauge for spikes or creep and make sure it doesn't go above your set amount of boost.
After the WOT pull check your IC piping couplers, check all the oil lines and turbo for oil leaks. Check your radiator hoses, fuel lines, all vacuum lines etc for leaks.
Old Apr 30, 2005 | 11:15 AM
wantboost's Avatar
Who is Mr Robot?
your shop has been installing too many greddy kits apparently. greddy has some crap printed in their instruction manuals (if you can get one, lol) that there turbos must be broken in for at least 500 miles seeing no boost... dunno why they do it exactly, probably has something to do with a new chra and new bearings
Old Apr 30, 2005 | 12:01 PM
Default Re: Breaking in a turbo? Wtf? (wantboost)
500 miles no boost..That would suck.
Old Apr 30, 2005 | 12:49 PM
HiProfile's Avatar
Default Re: Breaking in a turbo? Wtf? (Treblarefils)
Besides that, the only reason I could think of is that they don't want to be liable for running it as is, which I'm guessing is with stock fuel system. Unless there's some sort of management, I wouldn't go past 2psi, although even that will probably send the ecu into limp mode.
Kits and their installs don't include fuel management unless mentioned otherwise. Same for tuning.
Old Apr 30, 2005 | 01:13 PM
SOHC_MShue's Avatar
Default Re: Breaking in a turbo? Wtf? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Besides that, the only reason I could think of is that they don't want to be liable for running it as is, which I'm guessing is with stock fuel system. Unless there's some sort of management, I wouldn't go past 2psi, although even that will probably send the ecu into limp mode.
Kits and their installs don't include fuel management unless mentioned otherwise. Same for tuning.</TD></TR></TABLE>
it sais in his sig that its a greddy kit so it should come with managment.
Old Apr 30, 2005 | 01:39 PM
.BigSexy's Avatar
most hood white kid
Default Re: Breaking in a turbo? Wtf? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
it sais in his sig that its a greddy kit so it should come with managment. </TD></TR></TABLE>
greddy kit doesnt come with EMS tho....comes with like a missing link or somethinging( not sure), but nothing like uberdata or hondata
Old Apr 30, 2005 | 01:54 PM
s2kdre's Avatar
Default Re: Breaking in a turbo? Wtf? (egcoupe94)
my sc61 broke in after a 100 miles.
Old Apr 30, 2005 | 02:12 PM
RACEPAK's Avatar
greedy kits used to come with blackbox that is just a missing link. after that thay had the bluebox that is a missing link and a elecrtonic fmu.
both are not tunable.
these days greddy kits comes with the e-manage.
Old Apr 30, 2005 | 02:47 PM
dasher's Avatar
Default Re: Breaking in a turbo? Wtf? (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">
Although Emanage is much better than what they used to include its still trash compared to hondata/uberdata/chrome.
Old Apr 30, 2005 | 03:14 PM
RACEPAK's Avatar
Default Re: Breaking in a turbo? Wtf? (dasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher &raquo;</TD></TR><TR><TD CLASS="quote">
Although Emanage is much better than what they used to include its still trash compared to hondata/uberdata/chrome.</TD></TR></TABLE>
Old Apr 30, 2005 | 05:45 PM
Si Shane's Avatar
Ntohing is wrong with any of that piggyback stuff so long as the boost is low (power output is low), and maybe the dist is pulled back a bit.
Old May 1, 2005 | 06:24 AM
I am hoping in the long run that I did not waste $2400. Yes I know you get what you paid for. I know I have a leak on the exhaust side and I think it's right between the exhaust manifold and the turbo itself. Would this cause me to loose HP? This this is not exactly pulling like crazy. I mean 4psi I should definatly be able to feel as apposed to stock. It seems like my second gear is a hell of alot longer than before. I am going to have to upgrade something else because this is BS.
Old May 1, 2005 | 09:55 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Integra GSR 95)
its a 15g.... it wont be like night and day
Old May 1, 2005 | 09:58 AM
Si Shane's Avatar
Default Re: (wantboost)
lol....
you car on a 15g will be slow till about 14-16 pounds, then you can hang with a stock camaro its not gonna feel fast at 3 pounds :D
jdjustme
Mar 9, 2007 01:05 PM
prabtej_si
Jan 25, 2005 09:02 PM
Cractos
Apr 23, 2004 12:22 PM
slwazgsr
Jun 23, 2003 03:45 AM
