Turbo maintenance
Old Apr 29, 2005 | 01:33 PM
lean's Avatar
Default Turbo maintenance
I searched but didn't find what I was lookin for. I have the snail off the car to change out the oil feed fittings along with various piping pieces required to remove the turbo from the bottom. Is there anything special or tricks-of-the-trade I can do while its all off in terms of maintenance or inspection, besides the obvious shaft play test?
Oh, and do you have a clue what kind of turbo this is? It came on the car and the previous owner claims its a full T4, but a second opinion would be nice.
Thanks yall
-jeff
Old Apr 29, 2005 | 01:35 PM
b16sedan's Avatar
Default Re: Turbo maintenance (lean)
That's a T3 hot side. Looks like a TO4E compressor side. That's all we can tell you about the turbo. It could support 350 HP, it could support 700.
Old Apr 29, 2005 | 01:40 PM
lean's Avatar
I figured it was a shot in the dark, but worth trying. Thanks.
Old Apr 29, 2005 | 01:51 PM
citrus3000psi's Avatar
from the pictures it looks like a .48 ar hot side and a .60 ar cold side. And like B16 said it looks like a t3/T04e. The turbine is fairly small I would recommend a bigger one depending on your application and hp goals. but that thing should spool up fairly quick.
Old Apr 29, 2005 | 02:32 PM
lean's Avatar
It ripped off 250whp at 11 psi tuned on a mustang dyno. I like the quick spool for autox and around town.
Any things I should do before I slap that sucker back on?
civic0104
Oct 2, 2006 05:03 PM
Demented
Apr 15, 2005 06:35 AM
DigitalFusion
Jun 16, 2002 08:01 AM
Markaccord95
Nov 22, 2001 04:56 PM
