What do you think?
Old Apr 28, 2005 | 07:59 PM
SuckMyDOHC's Avatar
Default What do you think?
I'm ALMOST done with my turbo on my 94 LS, i just need my charge pipes and a blow off valve but wondering what you guys think of my setup so far and if you think i should change or add anything...
T4 Turbo
Skunk2 Intake manfiold
generic *** 12:1 FMU
550cc injectors
walboro in tank fuel pump
golden eagle fuel rail
B&M FPR
johnny racecar FMIC
greddy evo exhaust
test pipe
any suggestions?? im plannin on running at about 8psi.
Old Apr 28, 2005 | 08:01 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: What do you think? (SuckMyDOHC)
the fuel pump plus 550's and a 12:1 fmu = your car not running... that would be way too rich
and to run a straight t4 at 8psi is pointless.... a t3 or t3/t4 hybrid would be better soutied to your goals
ditch the fmu and get real engine management, like hondata or uberdata... or even aem
and the stock ecu cant idle 550's much less drive them at wot
and the evo exhaust is a tad bit small, but it would work
Old Apr 28, 2005 | 08:07 PM
s2kdre's Avatar
Default Re: What do you think? (wantboost)
u cant use 550s with an fmu
Old Apr 28, 2005 | 08:12 PM
SuckMyDOHC's Avatar
well i was planning on getting hondata later anyways, but i guess i pretty much need it now if i wanna run with those injectors?
Old Apr 28, 2005 | 08:16 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (SuckMyDOHC)
um yea...
do you ever planning on building the motor or anything along those lines? any more info on this "T4" Turbo?
KaoticBrd
Oct 4, 2007 02:03 PM
StolenTeg
Jun 1, 2004 12:10 PM
kHoA DoGG
May 14, 2003 11:29 PM
speedy108
Apr 3, 2002 01:32 PM
