Is my afr safe?
Old May 2, 2005 | 03:09 PM
crx88fast's Avatar
Default Is my afr safe?
Ok i got my basemap made on turboedit and i am wondering if my afr is ok for driving around. At idle i am running pretty rich with a high 12 to low 13 afr. Just driving it goes up to the 14's soemtimes 15.. in full boost, which for now is 7-8 psi i am in the high 11's to low 12's. is this all ok for now except for the richness at idle? Also when i shift i am gettting like 17 and higher for the time that i am off the throttle and it is saying lean on the wideband and with my open dp i am getting a lot of backfire. like really loud.. so i just wanted to know if this sounds ok for now til i can get a new chip and learn turboedit pretty good. thanks
Old May 2, 2005 | 03:26 PM
crx88fast's Avatar
Default Re: Is my afr safe? (crx88fast)
Bump!!!!!
Old May 2, 2005 | 03:33 PM
SOHCmaster's Avatar
At idle after full warm up Im at 14.6ish going into WOT it bounces into 10.2 and holding solid 11s 11.4 11.6. @10psi
Old May 2, 2005 | 04:00 PM
dustin's Avatar
Sounds fine.
Is the car warm when you are getting 12:1 AFR at idle?
If so, lean it out a little until you get closer to 14.7:1.
Old May 2, 2005 | 04:15 PM
SOHC_MShue's Avatar
sounds fine other than idle. The lean spike when you shift is just from fuel cutoff when you let off the gas...that is normal.
Old May 2, 2005 | 04:17 PM
93supercoupe's Avatar
Default Re: Is my afr safe? (SOHC_MShue)
if u let off when u shift, lol
Old May 2, 2005 | 04:22 PM
alpha's Avatar
You are fine. Have fun.
Old May 2, 2005 | 04:29 PM
crx88fast's Avatar
Default Re: Is my afr safe? (0x64)
thanks guys that takes a load off of my mind.. would it be safe to take to the track this friday and see what it runs before i up the boost some more and tune it in? Yes my car is warm when i get those idle afr's and its around 13:1 or just a bit higher. and with it being so rich at idle is the only bad effect that it will get crappier gas mileage? any other harmful effects?
Old May 2, 2005 | 07:52 PM
PrecisionH23a's Avatar
Ring-wash... shoot for at least a 14.7:1 idle. When you shift or let off the gas to slow down you'll read lean (downshift or decel).
Old May 2, 2005 | 08:34 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx88fast &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys that takes a load off of my mind.. would it be safe to take to the track this friday and see what it runs before i up the boost some more and tune it in? Yes my car is warm when i get those idle afr's and its around 13:1 or just a bit higher. and with it being so rich at idle is the only bad effect that it will get crappier gas mileage? any other harmful effects?</TD></TR></TABLE>
you barely use any fuel at idle so gas mileage won't be effected by idle.
I'm always showin this picture to people :
Old May 3, 2005 | 03:31 PM
crx88fast's Avatar
Default Re: Is my afr safe? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Ring-wash... shoot for at least a 14.7:1 idle. When you shift or let off the gas to slow down you'll read lean (downshift or decel).</TD></TR></TABLE>
Will ring was really be something to worry about or would it only be bad with an even richer idle?
Old May 3, 2005 | 03:56 PM
ITR981002's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx88fast &raquo;</TD></TR><TR><TD CLASS="quote">Will ring was really be something to worry about or would it only be bad with an even richer idle? </TD></TR></TABLE>
You'd have to be way richer than you are at idle before you'd have to worry about ring wash.....
Old May 3, 2005 | 04:19 PM
SOHC_MShue's Avatar
Default Re: Is my afr safe? (ITR981002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR981002 &raquo;</TD></TR><TR><TD CLASS="quote">
You'd have to be way richer than you are at idle before you'd have to worry about ring wash.....</TD></TR></TABLE>
yea you should be fine.
Old May 3, 2005 | 08:53 PM
del_orson's Avatar
thanks for the help guys
welfarepc
Sep 13, 2007 05:15 PM
deftones0817
Jun 13, 2005 07:17 AM
ef_you_again
12
Mar 26, 2005 07:28 PM
echo999
Jan 28, 2003 12:37 PM
