low compression in cylander 1...help!!
ran compression test and got 190 across the board, except cylander 1 whic was dangerously low at 125. leak dow test broght it up a lil, but not much..
question is do i need to replace the valves, all or just the 2 intake and exhaust ones, or could it be the rings
any help would be appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DriveSideWays »</TD></TR><TR><TD CLASS="quote">this is a good one i want to know too! umm how do u do a compression test and what tools do u need? </TD></TR></TABLE>
just need a compression gauge.. and remove spark plugs...im sure theres a search on how to do it
warm the car back up. do the test again.
check cyl 1 if it reads low put a capful of oil down the cyl , recheck compression then. if it raises it up higher you have a problem in your block. most likely a issue with your ring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjohnson_2 »</TD></TR><TR><TD CLASS="quote">warm the car back up. do the test again.
retried and it went up to 185, so what u r saying is i need to replace the piston ring in that cylander right?
GSR_hatch936
Apr 5, 2007 11:04 AM
