obd1 iacv
Old Aug 16, 2004 | 10:27 AM
integlude's Avatar
Default obd1 iacv
what color are the wires that go to this im lost
Old Aug 16, 2004 | 11:25 AM
3.504's Avatar
Default Re: obd1 iacv (integlude)
colors where? on the car harness that plugs into the ecu? you want ecu pins? or do you want the color of the wires going into the harness clip for the sensor itself?
A9 = pin on ecu
a23 is the ground you'll use for testing on the ecu
yel/blk is 1 of the wires on the clip for the IAC itself, blk/blu is the other. hope that helps you
Old Aug 16, 2004 | 11:51 AM
integlude's Avatar
Default Re: obd1 iacv (3.504)
thats exactly what i needed i had the wrong plug hooked in there thats why it wasnt working. thanks
alx_90ef
Mar 18, 2010 01:22 PM
driftam1
Apr 25, 2008 09:13 AM
Samuels
Feb 14, 2007 03:16 PM
Teg_Your_It
Jun 17, 2006 05:08 PM
red97EX
Sep 20, 2005 10:42 AM
