Which ECU?
Old Aug 16, 2004 | 12:27 PM
jdmb20gsr's Avatar
Default Which ECU?
K, sorry to bother everybody again but which ecu should I be running with a B20B? The guy that put the motor in just told he didnt touch the original but today I went to Acura/Honda specialist in PTC, GA and I found out the ecu I have been running this whole time was a damn 92-95 Cx one....boy am I ticked right now....I cant even get ahold of the installer either.... The shop I just visited said try and get a 92-95 Prelude Si of a LS....what is anybody running?
Old Aug 17, 2004 | 10:51 AM
R-Toyz.com's Avatar
Default Re: Which ECU? (jdmb20gsr)
whats your setup and are you running obd1? the safest would be to get the stock b20 ecu. most ecus will run that motor, even the cx one....but to run the motor well or run it optimally, you will definitely need more than a stock ecu. why not have the cx computer rechipped to run a B20? its possible and guys like us can do it. no need to swap ecus...make the most of what you have now you have options
kp
20
Feb 2, 2012 05:05 AM
DB1_559
Mar 6, 2007 11:49 PM
riceburnah
May 31, 2003 08:13 PM
CivilizedCiv
May 29, 2003 11:43 AM
