ls heads
Old Aug 16, 2004 | 03:36 PM
B20b4door's Avatar
Default ls heads
has anyone with a 94-95 ls ever had a pr4 head? those are for 92-93 cars only, right? i feeel as though i have been ripped off by engineered performance in smyrna, GA. im sure 94-95's had p75 heads right. pr4 heads are ****, like 130 hp rite? i just realized what happened to me 2 years ago and i am kinda mad now.
on the good side, i have a p8r head i can put on my b20. now it looks like i should do it sooner than later. my pr4 cams in my p8r head w/ the under 30,000 mile valvesprings and the great ports n stuff should be a good increase in power
Old Aug 16, 2004 | 03:45 PM
arw321's Avatar
Default Re: ls heads (B20b4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20b4door &raquo;</TD></TR><TR><TD CLASS="quote">has anyone with a 94-95 ls ever had a pr4 head? those are for 92-93 cars only, right? i feeel as though i have been ripped off by engineered performance in smyrna, GA. im sure 94-95's had p75 heads right. pr4 heads are ****, like 130 hp rite? i just realized what happened to me 2 years ago and i am kinda mad now.
on the good side, i have a p8r head i can put on my b20. now it looks like i should do it sooner than later. my pr4 cams in my p8r head w/ the under 30,000 mile valvesprings and the great ports n stuff should be a good increase in power</TD></TR></TABLE>
The difference is minimal. If you have the head ported, it really doesn't make a difference which casting you start with.
You weren't ripped off. It's still an LS head. From the factory, it has slightly smaller ports.
Old Aug 16, 2004 | 03:49 PM
B20b4door's Avatar
Default Re: ls heads (arw321)
but its the combustion chamber shape that is different between pr4 and p75's, rite?
isn't that where the extra 12 hp come from?
Old Aug 16, 2004 | 04:47 PM
Darkane's Avatar
My B18B came with the PR4 head - '95 Teg SE.. so I think the head is the same, but the intake manifold+cam profiles are different resulting in more power.
Old Aug 16, 2004 | 05:10 PM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20b4door &raquo;</TD></TR><TR><TD CLASS="quote">but its the combustion chamber shape that is different between pr4 and p75's, rite?
isn't that where the extra 12 hp come from?</TD></TR></TABLE>
Combustion chambers are the same.
Extra power comes from intake/exhaust manifolds and mainly the cams. Don't forget that the 92-93 RS/LS/GS were rated at 140hp. (same PR4 head).
The head doesn't have much to do with the power difference.
vtec killin
Jun 26, 2007 12:06 PM
b20turboic
Nov 20, 2005 07:59 AM
Intellect
Jun 13, 2004 10:15 PM
J-Spec EG
May 7, 2004 09:38 PM
UltRaH22
Mar 27, 2003 10:20 AM
