HELP... Getting new header
Old Aug 14, 2004 | 09:15 AM
ANDREW D's Avatar
Default HELP... Getting new header
I plan on getting a comptech header (unless anyone thinks there is something better in that $$ range), should I replace the gasket and will it come with one??
Any Help would be appreciated
Old Aug 14, 2004 | 09:43 AM
RallyRedGT-V6's Avatar
Default Re: HELP... Getting new header (ANDREW D)
Yes, replace the gasket..ALWAYS replace the gasket...well i didnt once, thats cause it was only installed for like 10 minutes, and i hadn't tightened the manifold all the way
and it probably won't come with one...go to autozone...8-12 dollars
Old Aug 15, 2004 | 05:17 PM
ANDREW D's Avatar
Default Re: HELP... Getting new header (96integra)
thanks
Old Aug 15, 2004 | 05:28 PM
timmy8151's Avatar
You should replace the donut gasket between the header and the cat. However, the gasket between the head and the header doesn't have to be replaced.
Old Aug 15, 2004 | 05:32 PM
furious94ls's Avatar
Default Re: HELP... Getting new header (timmy8151)
It will cost you about $20 at the dealer (did for me) to replace both gaskets. Why not just get both and be safe?
EricUSC
May 23, 2004 01:04 PM
Loveless
Jul 29, 2003 08:41 PM
cccccccc
Jun 19, 2003 11:03 PM
norice
Dec 19, 2001 11:33 AM
