header question
Old Aug 14, 2004 | 08:50 AM
Integra99's Avatar
Default header question
i have an ls engine and my buddy has a b16 4-1 header, is it a good idea to put it on, or will the header restrict the motor. ( this is what i have heard so i am just trying to find out) thanks.
Old Aug 14, 2004 | 10:37 AM
Integra99's Avatar
bump
Old Aug 14, 2004 | 11:43 AM
LSvtec03's Avatar
Default Re: (Integra99)
no, it will not restrict your motor. just make sure that its the right length to fit up to your cat
Old Aug 16, 2004 | 01:02 PM
Integra99's Avatar
are you sure about this. dont want to buy it and have some problems. lol
Old Aug 16, 2004 | 01:13 PM
purplegsr's Avatar
He is sure, it will bolt up exactly the same for all B-series motor, you run into problems with the length of the runners/collector. Just modify your exhaust, test pipe, or cat in order to fit it properly.
Old Aug 16, 2004 | 01:26 PM
Integra99's Avatar
yeah i know it will fit up, but someone told me that the exhaust ports might not match up to the b16 header perfectly (like a couple of millimeters off) in which not getting the full effect of the header and restrict the motor. Im just not sure if this is true or not.
Old Aug 16, 2004 | 01:32 PM
purplegsr's Avatar
I never heard that before, my assumption is that all of the B-series exhaust ports are the same measurements. You could measure both and find out, or call the company that makes the header to make sure.
Old Aug 16, 2004 | 01:42 PM
Integra99's Avatar
thats a good idea, ill line it up and see if its matches. Maybe the guy wasnt quite sure or thats what he heard. but thanks for the info man.
Jamarquis
Mar 18, 2006 02:59 AM
JDM00SI
Aug 30, 2005 10:22 AM
93H22A
Dec 10, 2004 07:01 PM
integerkgsr
Jan 22, 2004 10:08 AM
SpdFrk
Jul 7, 2003 12:10 AM
