Cluster Problems :/
Old Jul 21, 2012 | 10:46 PM
KingRibbo's Avatar
Default Cluster Problems :/
so i just got a da9 1990 ls integra yesterday and noticed that some of the bulbs in the cluster were out. i decided to pop the cover off unclip everything and take a look behind the cluster. i replaced all the bulbs everything went smoothly, but when i finally got everything back together i noticed the speedometer and the mileage counter wasn't working. I'm pretty sure i put everything back the right way, not too sure why they're not working anymore. i was instantly heart broken cause i always tend to assume the worst. 22 year old wiring isn't the easiest thing to fix. And if wiring is the case i'm screwed cause i have no idea what the hell im doing when it comes to wiring. anybody else know why maybe? any help would be great thanks guys.
Old Jul 21, 2012 | 11:17 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Default Re: Cluster Problems :/
Make sure that you did put everything back correctly. I forgot if the DA runs on cable for the speedometer. I think it does.
Old Jul 21, 2012 | 11:23 PM
KingRibbo's Avatar
im sure i did, cause the rpm gauge works fine, not sure about the gas meter haven't drove it around much. but i'll go snap some pictures of what i think is the problem for you, cause there is this wire looking thing just hanging out back there not plugged into anything.
Old Jul 22, 2012 | 01:08 AM
Solster's Avatar
the speedo is cable on the 90~93 gen2 tegs.
you may may need to unhook it from the trans and push some of the cable inside the car to reconnect it to the cluster.
burnykawizzle
Apr 27, 2010 07:55 AM
1991hb
Feb 8, 2007 04:38 AM
CRX_Type_R
Jun 14, 2004 03:16 PM
adam`
Apr 25, 2004 04:51 PM
creasian
Sep 30, 2002 04:03 AM
