93 teg ls problem
Old Jul 1, 2012 | 02:05 PM
heato's Avatar
Default 93 teg ls problem
Ok so...sitting still my cars fine radio doesn't cut out or anything but once I get going it loses power..my temp gauge is erratic to hot sometimes..radio cuts in n out at night my lights flicker when I give it gas..ac will turn off n lights will too taking off in 1st driving normal..my only ce light code is o2 .. Any ideas. Can give more info if needed.
Old Jul 1, 2012 | 02:13 PM
heato's Avatar
Default Re: 93 teg ls problem
I've checked all the fuses..pulled pos terminal off while running stayed on..battery is good so is alternator..I'm stumped.
Old Jul 1, 2012 | 08:23 PM
Royal_DB2's Avatar
Check all the grounds make sure none are disconnected or loose.
Old Jul 1, 2012 | 09:38 PM
teggy!'s Avatar
check the voltage from alternator and battery voltage.
Old Jul 1, 2012 | 11:10 PM
el crapitan's Avatar
i second this. check and clean all underhood grounds and battery connections. voltage drop testing the ground connections is the ideal method. voltage drops should not exceed 100mv.
if this doesn't find the culprit, a thorough charging system test should be performed, since the problem seems to occur under load. you can check the charging voltage yourself, and measure a/c ripple, but for a load test, it's best to have this performed by a shop
wagstation
Honda CR-V & Element
Sep 18, 2017 03:18 PM
Boosted_eg19
May 1, 2009 09:06 AM
mandalorianjedi
Dec 19, 2007 11:46 PM
Keno20
Jul 3, 2005 07:27 PM
Buckshot
Dec 12, 2002 08:11 PM
