Cusco Coilover Problem
Old Jul 21, 2012 | 03:02 PM
Tekkno's Avatar
Icon2 Cusco Coilover Problem
I was gonna buy a set of used Cusco Coilover, but i was thinking about if it will require a Type R LCA to install it in our Non-R integra? i asked the owner but he said he is not sure if it is for Type-R or not.
so any one know did cusco had Coilover that is not made for Type R?
if no, anyone has a write up for how to install Type R LCA ? thank you
Old Jul 21, 2012 | 04:42 PM
doood's Avatar
been there done that
Default Re: Cusco Coilover Problem
AsK for pics
Old Jul 21, 2012 | 06:15 PM
SolScifen's Avatar
All the ones I've seen are for type r lca's. I'm pretty sure they bolt up the same on the hub and subframe.
Old Jul 22, 2012 | 02:44 AM
Tekkno's Avatar
Thanks for your reply.
so basically i will need a TYPE R LCA for these coilovers?
no pics in hand now :S
anyway, do we have any write ups for installing LCAs? thank you
Old Jul 22, 2012 | 03:03 AM
zcegdx's Avatar
I run cusco zero2 on my hatch.
They use itr rear lca
They install the same way your stock ones come off. Its about the easiest possible thing to changeout.
Old Jul 22, 2012 | 09:36 PM
Tekkno's Avatar
Thank you!
Old Jul 23, 2012 | 10:01 AM
doood's Avatar
you'll need the itr lca's
Old Jul 23, 2012 | 11:07 PM
Tekkno's Avatar
Old Jul 24, 2012 | 06:20 PM
Tekkno's Avatar
How did you know it requires ITR LCAs by just looking at the pic?? i would like to learn how to, so i could figure out which suspension requires ITR LCA.
THank you!
Old Jul 24, 2012 | 06:29 PM
doood's Avatar
the rear shocks. normal integra shocks use a fork type deal on the bottom. itr shocks use that eyelet style.
integra
itr
alfaaay
May 22, 2005 10:18 AM
ITR0950
Sep 18, 2004 05:59 PM
GRM Scott
May 7, 2004 03:57 AM
JDC2
Jun 2, 2002 08:23 PM
