AUTO TRANNY PROBLEM???????????????????????????
Old Jul 19, 2012 | 10:14 PM
DC2.KILLA's Avatar
No Sales Forums
From: where your homies are fake as four dollar bills
Default AUTO TRANNY PROBLEM???????????????????????????
i got a 95 integra and its auto. when i turn on the car and push in the brake to shift into revears or drive it wont unlock.its stay lock i have to take the key out and put it in the shift unlock part. anyone no the problem???
Old Jul 20, 2012 | 06:39 AM
DC2.KILLA's Avatar
No Sales Forums
Default Re: AUTO TRANNY PROBLEM???????????????????????????
Old Jul 20, 2012 | 07:24 AM
kyden's Avatar
do your brake lights work?
Old Jul 20, 2012 | 07:57 AM
DC2.KILLA's Avatar
No Sales Forums
no
Old Jul 20, 2012 | 08:02 AM
DA6righthand's Avatar
It's a good idea to checkthis! There's a little switch on the pedal assembly that activates the brake lights when you push the brake pedal and allows the gear selector to be moved. Do you have any problems switching between the other gears?
Old Jul 20, 2012 | 08:17 AM
DC2.KILLA's Avatar
No Sales Forums
it wont come out of park. all the other gears are cool just when i go back to park it locks
Old Jul 20, 2012 | 09:02 AM
MoreCowbell's Avatar
Did you mess with the tps sensor at all? If not I figure it's a inter lock solenoid that went out. I may have one still I can sell you cheap if it is.
Old Jul 20, 2012 | 09:09 AM
DC2.KILLA's Avatar
No Sales Forums
all the lights work on the tail lights but the brake lights? i check the fuse there all good
Old Jul 20, 2012 | 09:11 AM
kyden's Avatar
there's your problem, lol. check your brake switch.
Old Jul 20, 2012 | 09:23 AM
DC2.KILLA's Avatar
No Sales Forums
the one behind the pedal? how you know when it goes bad?
Old Jul 20, 2012 | 11:26 AM
DC2.KILLA's Avatar
No Sales Forums
Old Jul 20, 2012 | 03:50 PM
Read the posts. Your question is answered! lol
Old Jul 20, 2012 | 04:14 PM
Hidenplanvew's Avatar
Brake switch is bad! Replace it, it takes all of 10 min and 22 bucks if I remember correctly
Old Jul 21, 2012 | 09:27 AM
DC2.KILLA's Avatar
No Sales Forums
replaced it still dont work!!!
Old Jul 21, 2012 | 10:29 AM
DC2.KILLA's Avatar
No Sales Forums
what else can it be?? fuses are all good. tryd 3 brake switches. idk what to do.
Old Jul 21, 2012 | 12:53 PM
DC2.KILLA's Avatar
No Sales Forums
Old Jul 21, 2012 | 02:14 PM
Does the gear selector work correctly when switching between other gears? You may just have a bad connection somewhere. What about the shift cable? Is it loose? It may need an adjustment.
You won't find too much help here with automatics. Nobody wants or likes them, that's just the truth.
Old Jul 21, 2012 | 11:36 PM
BlueDA8's Avatar
i have one problem with my auto tranny.. it wont shift to 4th gear. the s4 light is blinking.. could it be wiring issues?
Posted from Honda-tech.com App for Android
Old Jul 22, 2012 | 05:08 PM
S4 light? Try adjusting the shift cable. That's my only guess.
Old Jul 22, 2012 | 06:37 PM
If you replaced the brake light switch and they still don't turn on you prob have a wiring issue.. Check for voltage at the connector
Old Jul 25, 2012 | 12:27 PM
KILLA, I think I can help. In my Haynes manual, ir says the shift lock solenoid could be malfunctioning. Hopefully this picture helps:
Side of gear selector with center console removed
Page 1:
Page 2:
Hopefully that's readable.
Old Jul 25, 2012 | 04:25 PM
DC2.KILLA's Avatar
No Sales Forums
i found out aready. it was the horn fuse never new that could stop it from working
Old Jul 30, 2012 | 04:57 AM
BlueDA8's Avatar
Hey man thanks alot. I recheck the cables and yea it did it. Now i have 4th gear. :-)
Old Jul 30, 2012 | 05:02 AM
BlueDA8's Avatar
Heyy guys i have another problem. It seems that my flywheel oil seal is leaking. Can u guys help me out with replacing it?
Old Jul 30, 2012 | 07:30 AM
kyden's Avatar
remove transmission, replace seal.
HKeller
Honda Civic (2001 - 2005)
Dec 5, 2016 09:19 PM
mattyk85
Aug 20, 2007 05:05 PM
Jahtoot84
Aug 15, 2005 07:59 PM
94TealGSR
Oct 25, 2002 11:41 AM
