Stripped block threads, rear block fitting
Old Jul 1, 2012 | 08:55 AM
TravisBiggie's Avatar
Icon2 Stripped block threads, rear block fitting
I took the two fittings off the block to install prelude fittings for a catch can. I decided to put the stock fittings back in cause I didnt have everything I needed. Anyways I screwed a fitting in, which twisted in quite easy crooked, and i couldnt see anything. Anyways realized i ****ed up, tool the fitting out, pieces of metal everywhere. The fitting screws in crooked no problem, but when i try to twist it in aligned, it just spins and wont thread in, didnt try too hard cause i dont have much room for my big hands.
Can someone please tell me if Im ****ed or not? If i can, i just want to plug this port up and forget about it, or possibly use my prelude fitting still. Hopefully the Block isnt ****ed. I think its 28mm
Thanks
Old Jul 1, 2012 | 09:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: Stripped block threads, rear block fitting
http://www.helicoil.in/ 94
Old Jul 1, 2012 | 09:43 AM
teggy!'s Avatar
^^ what he said
Old Jul 1, 2012 | 10:34 AM
They don't make 28mm, only 27 and 30. ****, i gotta find a way to screw it in evenly so I can jb weld it, or so I screw it in **** eyed and jb weld it? ><
Old Jul 1, 2012 | 04:05 PM
fcm's Avatar
fcm
Old Fart
Then go to a 30mm. 94
Old Jul 1, 2012 | 05:44 PM
I got the fitting in lucky lucky me.
Old Jul 3, 2012 | 02:53 AM
Solster's Avatar
Glad you fixed it but just for the record all the sensors and line fittings on the block are threaded in NPT (national Pipe Thread) this means as you tighten them they seal by a Tapered thread on the fitting/sensor
this is only for fittings and sensors on the block and with No other type of seal under them
jeremiah87
Nov 19, 2008 02:17 PM
SequenceGarage
Welding / Fabrication
13
Dec 30, 2006 01:14 PM
T3mp3sT
Feb 23, 2005 03:02 PM
-iLLuZioN-B18C1
Aug 4, 2004 06:19 AM
