Ecu codes with step down
Old Jul 16, 2012 | 02:27 PM
bebe1320's Avatar
Default Ecu codes with step down
Ecu codes with step down harness
Yo Honda tech watsup.ive always delt with obd 1 civics never had a kick down harness..whatever......I have a 96 integra now ..it has a kick down harness and chipped po6 ecu..my check engine light is on.how do I go about check codes.i try to plug in scanner and figuring it was a obd 1 ecu it didn't communicate with ecu....obd 1 you have jump the plug under the glove box....any help would be appreciated....
Old Jul 16, 2012 | 02:44 PM
bebe1320's Avatar
Default Re: Ecu codes with step down
Sorry guys I screwed up..my maintenance required lit is on.....but is that consider the check engine light? In my ntegra I'm sorry for posting in civic section.
Old Jul 17, 2012 | 07:25 AM
cvcrcr99's Avatar
No, they are not the same.
Old Jul 18, 2012 | 09:47 AM
bebe1320's Avatar
Your right .tnx.i found the oil box under dash to reset maintenance light...I think someone took out the buld o check engine light..icicle the key forward and the light never turns on.
Old Jul 18, 2012 | 10:53 AM
RollinarexBBM4M's Avatar
yea the maintenance required light turns on every 4 or 5 thousand miles by itself. like a reminder i guess...
Old Jul 18, 2012 | 01:18 PM
cvcrcr99's Avatar
Pull the cluster out and replace the bulb.
Old Jul 18, 2012 | 01:59 PM
bebe1320's Avatar
Exactly what it was...broken bulb. Not even blown..however the light isn't on..no codes..yay..l
alperx
Engine Management and Tuning
Sep 4, 2011 08:35 PM
1320king
Jul 22, 2007 12:32 PM
dre000
Jan 19, 2003 01:36 AM
mrduque
Jun 12, 2002 12:01 PM
petrv
Jan 4, 2002 07:37 AM
