Integra compression test
Old Jul 4, 2012 | 05:17 PM
Prboy's Avatar
Default Integra compression test
Hey guys i did the compression test and this are the results.
Cyl 1. 195
Cyl 2. 150
Cyl 3. 195
Cyl 4. 240
What is going on? First time i see this, i just did piston rings and honing 50 miles ago.
Old Jul 4, 2012 | 06:08 PM
racebum's Avatar
Default Re: Integra compression test
did you measure bores for out of round? did you check the valves for any leaking? what's going on is you have a cylinder reading much lower than the others
cylinder out of round, rings that aren't sealing and leaking valves are the most common causes
Old Jul 4, 2012 | 07:09 PM
Prboy's Avatar
Cheapest fix would be anothe block, isnt it?
Old Jul 4, 2012 | 07:13 PM
cagedGSR's Avatar
no, not necessarily, cheapest fix would be figuring out the problem, first... Then spending the money to fix it. It could be head/valve related and not block
Old Jul 5, 2012 | 04:46 AM
Prboy's Avatar
Cool. I just started taking it apart, took valve cover off and my buddy crank the car and valve movement looks good so far. Let see what i can find and keep u guys updated, sometng specific i should look for?
Old Jul 6, 2012 | 05:58 PM
ZombiePharoh's Avatar
leak down test. you wont see the valves leaking.
Old Jul 6, 2012 | 09:22 PM
racebum's Avatar
if you don't understand how to build an engine properly, sell it off and buy a stock jdm engine
Old Jul 6, 2012 | 09:25 PM
grjr's Avatar
did you check your piston ring end gap? If you just replaced the rings 50 miles ago then you must have missed something to say the least.
edit: what was the problem before replacing the rings?
Old Jul 6, 2012 | 09:30 PM
JuicedUpRice's Avatar
pull out your spark plug with the low compression and see if there is oil on the bottom of it.if not, you might be in luck and just need to do a valve adjustment.
Old Jul 7, 2012 | 09:32 AM
Prboy's Avatar
Ok guys i started this topic in order to get to the bottom of my problem, loud knocking cuz didnt want to take the engine apart. Well took the engine apart and guess what, a spun rod bearing. I was actually parting out the car but now i might get it running and sale it for cheap. So my question is what kind of rod bearing should i get if im using b20 crank and ls rods? Thx
nemesis25
Jan 12, 2015 04:17 PM
89civichb
11
Mar 10, 2009 08:26 AM
Dave_Dc2
Mar 21, 2008 05:35 PM
Da1spaz247
Nov 4, 2005 07:57 PM
Goldfingiz
Dec 13, 2002 10:30 PM
