Foglights
Old Jul 7, 2012 | 03:43 PM
Stock_LS's Avatar
Default Foglights
So i bought this aftermarket Civic 99-00 fog lights and it all comes with everything: wires, switch, 30amp fuse, lights, etc.... I retrofit in on my 01' Integra so to make the story short I did the wiring and hooked it up from cigarette lighter. After all the installation and wirings i turn it on and it did for like 4-5 times and after that it wont turn on again. So i checked the 30amp fuse and it was burnt. Now my question is how can i make this thing work w/o burning the fuse ? do i have to wire it somewhere else or can i just get a higher amp fuse ? What causing it burn ? Please help me....
Thanks in advance....
Old Jul 7, 2012 | 03:45 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: Foglights
are you serious? hooked up to your lighter? no don't put in a bigger fuse, you should have never blown a 30 amp fuse, you probably blew the lighter fuse,wire it up right for gods sake
Old Jul 7, 2012 | 03:59 PM
Stock_LS's Avatar
so where should it be ?
Old Jul 8, 2012 | 01:54 AM
the 30 amp fuse hooks to the battery and there is supposed to be a wire from the switch that goes to 12 volts somewhere to switch the lamps off with the ignition , does someone have an exact diagram? that high current fuse though can't come off the lighter, if you blew a 30 amp fuse you probably damaged some of the wiring somewhere, if you don't know anything about wiring, as I can guess you don't, I'm hesitant that you hook this up yourself or you are liable to set your car on fire
Old Jul 8, 2012 | 11:31 AM
Stock_LS's Avatar
damn it !! now how can i know or find if i burn some wiring ???
Bleakened
Nov 6, 2015 12:04 PM
sweatyjack
Sep 11, 2013 06:10 AM
ERKK
10
Dec 15, 2010 07:48 AM
taimysho0
Jan 17, 2009 06:32 AM
EJ8CIVIC
18
Feb 8, 2008 04:18 AM
