quick question about electricity.
when someone says battery power and ignition power..
can i use and empty slot by the fuse box that is always with power for the "battery power"
and one that tuens on when i tuen ignition for "ignition power"??
this is for when i wire up my relay for my power windows
92 teggy
92 teggy
typically B+ is considered constant. while ignition is keyed power.
i imagine the B+ is to be wired to the load side of the relay, and keyed power to the control side.
terminal 86 is keyed power, 85 ground, 87 constant, 30 load. 86 and 85 are the control or coil side, while 87 and 30 are the load side
Answer is yes, be sure to run appropriately sized inline fuses on all power connections, constant and switched as close as possible to where you make the connection to power.
jetspeedz
Audio / Security / Video
Jun 7, 2010 07:58 AM
EKidd
Jun 1, 2007 09:32 PM
mpowers69
Acura TL, RL & ZDX
May 31, 2005 02:31 PM
