How do u adjust Integra's cambers?
Old Mar 16, 2007 | 10:41 AM
jdm_BlaZe's Avatar
Default How do u adjust Integra's cambers?
Yeah i got a DA that is slam to the floor and i can't put big rims on the front. I tried adjusting it but it's still mess up. I got them rhino cambers off ebay,so it looks kind of like the stock ones. Anyone got any tips or advice?
Old Mar 16, 2007 | 11:18 AM
doood's Avatar
been there done that
Default Re: How do u adjust Integra's cambers? (jdm_BlaZe)
crazy idea....try raising the car
Old Mar 16, 2007 | 12:25 PM
hatchling37's Avatar
Default Re: How do u adjust Integra's cambers? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">crazy idea....try raising the car</TD></TR></TABLE>
Haha
But seriously, you can find aftermarket upper control arms that allow for adjustment of camber and caster. Just search some companies- maybe JC Whitney has them. Don't know who else to call other than my parts supplier for my work
Old Mar 16, 2007 | 01:09 PM
TunerN00b's Avatar
The correct way to adjust camber on an Integra, unfortunately, is to not adjust it. Seriously. Our cars lack front suspension travel. A replacement UCA will be taller than stock, due to the sliding balljoint. This means, the UCA will limit travel even further (it will hit the inner metal fender before the shock bottoms), meaning you have to run a higher ride height for the same springs, or raise the car, to avoid bottoming after you replace the UCAs.
And trust me, slamming the UCA into the fender sucks. I do it occasionally on potholes and abrupt freeway overpass transitions. Its harsh, loud, and eventually my UCAs will make more clearance for themselves by just cutting through or denting the impact point. I also am running SPC UCAs, which are some of the thinnest aftermarket camber adjusting UCAs I've seen (thinner than the skunk2 units), so they'll leave the most travel afterwards. I also had to raise the car 1" after adding the UCAs, to bottom out about as rarely as before, because of the decreased suspension travel available. I'm also using them for more camber, and daily drive with -4.0* in the front, and I don't suffer from the supposed "camber wear" people are always afraid of.
Lower the car. Accept that you'll have more negative camber. Get the toe corrected with an alignment (lowering screws the toe setting, and toe eats tires). Enjoy the increased cornering the camber provides. That is why we lower the car to begin with, right?
civicnoob
Suspension & Brakes
17
Nov 25, 2007 03:12 PM
Backk InTheDA
Jul 17, 2006 03:38 AM
AmginE
Nov 9, 2005 11:08 PM
93formula
17
May 7, 2005 06:27 PM
96civich22
Suspension & Brakes
35
Apr 1, 2005 02:11 PM
