Need help ASAP!
Tonight I was futzing around under the hood of my 94 LS and i took the valve cover off to strip the paint off because it was peeling pretty badly. Now I've reassembled everything just as I had taken it off and the damn thing wont start. I can hear the starter motor running but theres no cranking.
When I took her apart I disconnected the battery and the spark plugs (obviously) and I checked the fuses, none are blown. All my accessories turn on; radio, lights, etc. I just cant get the stupid car to start. Any suggestions?
Edit: Sorry...Didn't search, just impulsive to post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">You sure the plugs are connected properly,
Did you disconnect them from the distributor? </TD></TR></TABLE>
Yes they are connected properly.
No i didnt disconnect them from the distributor.
I dunno, backstep some more, and make sure Nothing else was disconnected.
But first thing, go out, and check for spark just to make sure, stick a plug, or screwdriver in the end of the wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">Pick up a new coil-pack from somewhere like autozone, I think they're fairly cheap.</TD></TR></TABLE>
I want to try to weed out everything I can before i go spending money... I already need 2 new headstuds, thanks to my dad and i
