hard starting
Old Mar 18, 2007 | 06:37 PM
dohcgarage@714's Avatar
Default hard starting
hey guys need some tech info sometimes when i try to start my car cold or hot
my starter wont crank over i can hear the gear pop out but it wont turn over
i have to open and close my switch like 10 times and then my car will start what do you think is wrong with my starter????
Old Mar 18, 2007 | 06:50 PM
EvilEyez's Avatar
Default Re: hard starting (dohcgarage@714)
1. make sure you battery is fully charged.
2. check fuses.
3. check wiring.
4. check over the entire engine for anything suspicious, leaking ripped torn etc.
5. have your started checked.
if your starter is just clicking, its most likely your battery holding it back from turning over or actually spinning. unless its stuck or something then your starter would be bad. also make sure you aregetting fuel to all lines and **** to make sure.
thirty3
Mar 23, 2013 11:14 AM
topp_dawg_g
Oct 12, 2008 10:42 AM
go2sleep
May 6, 2007 08:42 PM
mingchi69
Jul 14, 2003 06:14 PM
mattL
Jun 25, 2002 07:33 PM
