Antenna
Old Mar 17, 2007 | 03:41 PM
almostboostedgsr's Avatar
Default Antenna
i just got a simple question. What options do I have for my rear antenna, because the stock on is so darn tall it looks like im talking to alliens or something. Ive heard people putting the s2000's antenna on an integra.
I either want to do an s2000's antenna. Or still have it electronic but not so tall.
Also how do you make it so that when the cd player is on the antenna is not up.
Thanks if someone could help me out.
Old Mar 17, 2007 | 03:53 PM
Benhawk's Avatar
Default Re: Antenna (almostboostedgsr)
I found this to be helpful.
http://www.team-integra.net/se...D=815
Old Mar 17, 2007 | 03:54 PM
Benhawk's Avatar
Sorry, this is the on for the s2000.
http://www.team-integra.net/se...D=859
Old Mar 17, 2007 | 04:10 PM
Default Re: Antenna (Benhawk)
Thanks for posting that information. That oem antenna has to go. Im going to the honda dealer next month and picking up an s2000 antenna.
Old Mar 17, 2007 | 04:36 PM
DjMigs's Avatar
i would suggest locustom website and pick up a shark II its resemble if not identical to a s2k just easier to install them the oem s2k....
Old Mar 17, 2007 | 05:17 PM
98GSRDC2's Avatar
Default Re: (DjMigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjMigs &raquo;</TD></TR><TR><TD CLASS="quote">i would suggest locustom website and pick up a shark II its resemble if not identical to a s2k just easier to install them the oem s2k....
yeah i heard its much easier
Old Mar 17, 2007 | 05:20 PM
bseries_ben's Avatar
Default Re: (98GSRDC2)
i have one. it takes about 3 minutes. mine's reception isn't as good as my oem one but i always watch movies or listen to cds so it doesn't really bother me. also, it's less than $40 shipped compared to i believe $120 for the entire oem assembly and i think the sharkII looks better on the dc body than the s2k does
http://locustom.com/shark2_kit.htm
Old Mar 17, 2007 | 05:26 PM
If your reception is not as good as oem, than the shark 2 is not what im going to get.
I want something that is electronic. Like it goes down in to the body than comes up like the oem one but it looks like an s2000 antenna.
I dont know if anyone has tryed it before.
Old Mar 17, 2007 | 05:37 PM
right on. i don't know how you're going to achieve that. gl
Old Mar 17, 2007 | 05:45 PM
Just thinking about it. I could take the actuator out of the oem antenna. Then make a mount for it. Mount the actuator part just like oem. Then when the radio goes on the actuator makes the s2000 antenna go up. I could weld the base of the s2000 antenna to the actuator.
Old Mar 17, 2007 | 05:49 PM
so what are you going to have a mast with an s2k antenna at the top when it's fully extended?
Old Mar 17, 2007 | 05:56 PM
Default Re: Antenna (clover99b18c1)
no no lol. Im saying shorten the arm on the actuator. Okay then mount the actuator like oem. Then measure the distance it needs to go up. Then cut the arm on the actuator to the correct length. Then when the radio turns on the antenna goes up to where the s2000's antenna would sit. Right on the body panel.
Just like the shark 2's look just mine would retrack inside the car and still have the gomment look just as if it was oem.
Old Mar 18, 2007 | 07:54 AM
oic. right on... don't know much about how antenna's actually work so i don't know if that would be better reception than the regular sharkII or s2k or anything, but it sounds kinda cool. do it and take pics
buymesomedunks
Jul 17, 2010 07:19 AM
LSracing94
Mar 23, 2010 05:35 AM
Jimmy
Jul 27, 2009 06:52 PM
bakertime
Honda S2000
13
Mar 27, 2008 07:38 PM
DJHan
Feb 11, 2002 01:46 PM
