5 lug conversion?
I know for sure that you can just swap hubs off the rear because the rear trailing arms are almost the same, just the ITR ones are a bit thicker, not sure if you could use the front knuckles though, but it can probably be done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bg-33p »</TD></TR><TR><TD CLASS="quote">I know for sure that you can just swap hubs off the rear because the rear trailing arms are almost the same, just the ITR ones are a bit thicker, not sure if you could use the front knuckles though, but it can probably be done.</TD></TR></TABLE> this is completely wrong. you can swap the itr front hubs right on, the rear will not fit tho. you need to pickup itr trailing arms aswell as the hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMorgan »</TD></TR><TR><TD CLASS="quote"> this is completely wrong. you can swap the itr front hubs right on, the rear will not fit tho. you need to pickup itr trailing arms aswell as the hubs.</TD></TR></TABLE>
Please have something to back up your accusations before you speak, i've seen it done myself.
just found out earlier today, that it can be done. will need frt calipers but the guy im getting the itr wheels from i am also getting his willwood brake kit as well.
thanks
thanks
1337 Si
May 23, 2004 03:52 PM
