Overheating problem
Hey one of my friend has a 97 integra LS stock everything.
Well he was driving like 2 hours on the hwy and then once he started driving local and caught a red light he said his Temp started going pass the 60% mark to High and then when he started to drive since it was green again the temp went back down.. This happened only when he was stopped but he said it doesnt do it anymore.. What do you guys think it is? can it be the thermo? waterpump lmk thanks
your fan rely fuse.....check that...also somtimes it work sometimes it does not wan to work...........that wat i hate about honda radiator fan.....
make shure your fans kick on first. start your car and let it run, a/c off. tell they kick on. if thery dont, check your thermostatic switch. its on the thermostate houseing. jump that 2 pin connector on the harness side and see if the fans kick on.
fans work we were out the other night i heard it turn on.. it turned on when the temp was getting higher and all it did was just stop it from going up and then once my friend drove it went back down... i think hes gonna change the thermostat and relay to be safe.. thanks
Did you bother to check the coolant level? That's the first thing you check. Check for leaks in the little hoses under the IM and throttle body. I am running an Autozone thermostat, no problems here after like 70K miles of it being installed, but mechanical parts can fail right out of the box. Make sure the system is bleed properly.
How many miles are on the motor? Since you said fan kicks in, first thing i would check is the hoses and thermostat. There is a thread on here where you can check your thermostat. Make sure fluids look good and full.
mike93eh
Mar 26, 2005 03:04 PM
ironchef25
28
Jul 28, 2004 08:57 AM
for thermostat. Also could be fans as previously stated. Check fans, if they work replace thermostat.
