tps code under load
Old May 24, 2007 | 08:56 AM
gsrlkn412s's Avatar
Default tps code under load
I purchased a prof. products 68mm tb for my slightly built gsr and ever since under heavy loads in second and third gear my cel will come on and when i jump the connector it flashes 7 short times which means TPS malfunction. could it be when i reinstalled the tps in the new tb that i didn't clock it correctly, i didn't use a multimeter to check resistance should i do that. i don't know the operating range thourgh.
Old May 24, 2007 | 07:22 PM
91slamedrex's Avatar
its really easy to adjust.
you need to loosen the screws on the back (might have to cut slits to loosen them)
then use a voltometer and attach the positive to the middle wire (red wire)
and the ground to a ground. Turn the tps until it reads .45v closed throttle and 4.55 wide open throttle.
Old May 26, 2007 | 06:02 PM
gsrlkn412s's Avatar
Default Re: tps code under load (gsrlkn412s)
thanks for the help crx
ElswickB22
10
Jun 6, 2014 11:08 AM
00323
Mar 19, 2011 02:37 PM
xander1100
Aug 17, 2009 12:10 AM
jmeyer99
Jul 30, 2007 05:45 PM
spastik
Dec 1, 2006 12:02 PM
