radiator issue
Old May 20, 2007 | 03:56 PM
ohmygsr's Avatar
Default radiator issue
i have a leak from my gsr radiator and i have a aluminum radiator for a civic
will it provide proper cooling for the engine?
Old May 20, 2007 | 06:46 PM
XskuLL's Avatar
Default Re: radiator issue (ohmygsr)
Old May 20, 2007 | 06:52 PM
iowecharles200's Avatar
throw it in there and try it out. if it does not work its not real hard to change it back.
im pretty sure it will be fine tho since some people use smaller radiators to make room for big turbo set-ups
Old May 20, 2007 | 06:56 PM
pvt_awol's Avatar
Default Re: radiator issue (iowecharles200)
yeah, it will cool the engine just fine. It's not gonna just "drop in and bolt up" though.
if you need proof of the cooling, think about the thousands of civics running stock civic radiators, with integra swaps of all trim levels. Works fine vice versa as well. You're just gonna have to be creative with the mounting.
Old May 20, 2007 | 07:40 PM
VTEC_PRODUCTION's Avatar
Default Re: radiator issue (pvt_awol)
its no problem at all...just need to cut the lower rad mount and move it over and weld for a proper fit just make sure the fan works haha...
Old May 21, 2007 | 10:11 PM
98GSRrdr's Avatar
Default Re: radiator issue (VTEC_PRODUCTION)
Weld or 100$ new one..
Old May 27, 2007 | 07:42 PM
ohmygsr's Avatar
thanks for the help with the rad. issue ill try it.
Old May 27, 2007 | 07:45 PM
ohmygsr's Avatar
yeah the fan issue, i was wondering about the compressor fan also shouldn't be to much
of a problem
lsvtecEM1
Mar 19, 2012 05:18 AM
lsvtecEM1
Mar 18, 2012 10:38 AM
DA is best
Jan 8, 2007 08:24 PM
95LSS
Jul 24, 2006 06:35 PM
TRM04
Jan 6, 2003 11:29 AM
