lsd question???
Old May 23, 2007 | 08:30 AM
buffgsr's Avatar
Default lsd question???
im about to order a engine off hmotorsonline.com and it says for an extra 300 it comes with lsd...is it really worth it im building a drag car will i get betting reaction times or is it made for cornering any help would be grea tthanks
Old May 23, 2007 | 08:31 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: lsd question??? (buffgsr)
Yes, an LSD is definitely worth it, especially if you're building a drag car.
Old May 23, 2007 | 08:34 AM
St Jimmy's Avatar
* B A N N E D *
When you say drag car I take it you mean its going to be only on the strip. Your best bet in that case would be just weld your differentall instead of spending money on a LSD.
Old May 23, 2007 | 09:09 AM
buffgsr's Avatar
Default Re: lsd question??? (St Jimmy)
what do you mean by that?>
Old May 23, 2007 | 09:13 AM
St Jimmy's Avatar
* B A N N E D *
Inside of your transmission are 2 parts that you weld together. Doing so makes both axels spin evenly no matter what. Thats easiest, cheapest way to get the best traction out of a drag car. After doing this the car wont be streetable.
Old May 23, 2007 | 09:28 AM
buffgsr's Avatar
i still want to drive it around every now and then on the road i will be a weekend racer
Old May 23, 2007 | 11:21 AM
TurboGS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Inside of your transmission are 2 parts that you weld together. Doing so makes both axels spin evenly no matter what. Thats easiest, cheapest way to get the best traction out of a drag car. After doing this the car wont be streetable.</TD></TR></TABLE>
You really thought he was building an all-out drag car?
and yes, obviously it is worth it ... unless you plan on getting a better limited slip like Quaife for example.
Old May 24, 2007 | 06:33 PM
TsujenDB1's Avatar
lsd is def worth it. :-D get fuccccked up
Old May 24, 2007 | 08:09 PM
hondacivic90zc's Avatar
Default Re: (TsujenDB1)
a little off topic on the lsd thing but i just wanted to pay so respect to hmotorsonline, when i bought my engine the service was extremely fast (in n out in like 10-15 minutes) and they are very friendly. They are definetely the way to go for an engine swap
Old May 24, 2007 | 08:55 PM
SkertySkerty's Avatar
dude just save the 300$ because the stock lsd is shitty newho and then buy you a good lsd like a quafe or phantom grip and put it in yourself its not hard just search for a howto in h-t but just save the money
Old May 24, 2007 | 09:52 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
quaifes are close to 900 dollars. i would just stick with stock LSD. you can still run really good times with open differential too.
Old May 25, 2007 | 09:55 AM
Default Re: (jdm_dc_fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan &raquo;</TD></TR><TR><TD CLASS="quote">quaifes are close to 900 dollars. i would just stick with stock LSD. you can still run really good times with open differential too.</TD></TR></TABLE>
true they are but then again if he needs to upgrade in the future he will be spending a total of 1200 instead of 900 correct?
Old May 25, 2007 | 12:38 PM
Hype-R Stalker
Default Re: (SkertySkerty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkertySkerty &raquo;</TD></TR><TR><TD CLASS="quote">dude just save the 300$ because the stock lsd is shitty newho and then buy you a good lsd like a quafe or phantom grip and put it in yourself its not hard just search for a howto in h-t but just save the money</TD></TR></TABLE>
You say a stock LSD is shitty, then mention phantom grip being good? wtf..
For hp most people will be making, and keeping it on the street, a stock LSD is fine.
Old May 25, 2007 | 02:39 PM
jdm_dc_fan's Avatar
+1 ^^
Old May 25, 2007 | 02:43 PM
personally i have no clue if phantom grip is good i have never used it but my friends car has it on a 220 N/A whp car and it seems to do fine i use quafe
Old May 25, 2007 | 03:59 PM
Dogginator's Avatar
Daisy... Daisy...
I'm not sure how you can claim the stock LSD is shitty when Quaife won't even provide the torque bias ratio for their Torsen-style LSD. The stock LSD at least has a functionality check procedure beyond broken and not broken. A Quaife LSD may be able to handle more WHP than the ITR LSD, but that does not mean that it functions better as an LSD in terms of traction.
Old May 27, 2007 | 05:19 PM
.PLUMMM's Avatar
LSD is def. tha way to go. Friend got it and he'll never go back to open diff!
Old May 31, 2007 | 07:20 AM
LsTboi's Avatar
LSD all the way!
SIRteggy
May 23, 2006 04:26 AM
sporkcrx
Mar 28, 2005 08:23 PM
CRVEF8
38
Jan 11, 2004 12:10 AM
vti2
Dec 7, 2003 12:23 PM
Heath
Oct 7, 2002 02:38 AM
