need suggestion
Old May 21, 2007 | 05:02 PM
whatan00b's Avatar
Default need suggestion
Ok I have a 92 ls with 164k miles motor and tranny in good shape. I have about 2500 I'd like to spend on it I've been considering a turbo but I don't know if I wanna deal with it also a lsvtec doesn't sound like a bad idea either. I'm only looking to make about 190hp something comparable to a new si my buddys is really nice to drive and I'd like mine to have that zip sorry about the giant run on sentence but I'm typing from a phone. Thnx in advance for suggestions or ideas timtim
Old May 21, 2007 | 05:29 PM
doood's Avatar
been there done that
Default Re: need suggestion (whatan00b)
if you dont want to deal with a turbo an lsvtec is not a good idea
Old May 21, 2007 | 05:55 PM
DC2_005200's Avatar
Get yourself a new motor. 164k miles is not going to play nice with an ls/vtec or turbo. just pick up another motor and save yourself the hassle with half *** build ups. Preping your motor for a turbo or a ls/vtec is going to cost you more the 2500 if you want to compare to something like the new Si
Old May 21, 2007 | 06:00 PM
doood's Avatar
Default Re: (DC2_005200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_005200 &raquo;</TD></TR><TR><TD CLASS="quote">Get yourself a new motor. 164k miles is not going to play nice with an ls/vtec or turbo. just pick up another motor and save yourself the hassle with half *** build ups. Preping your motor for a turbo or a ls/vtec is going to cost you more the 2500 if you want to compare to something like the new Si</TD></TR></TABLE>
do you know what his compression numbers are? do you know what the leakdown numbers are? do you know how well it was taken care of?
Old May 22, 2007 | 07:44 PM
DC2_005200's Avatar
i dont know, do you know? I am just saying as i believe many of the people in this form would say is its not worth the hassel. I means you are honest telling me that you would go ahead and invest in a motor that has 164k on it? I know honda motors are built tough but at some point even the most proper kept motor has to go sometime. Just my opinion tho.
Old May 22, 2007 | 11:57 PM
whatan00b's Avatar
I'm not sure the numbers the motor is pretty darn stout imho but a new motor sounds like a plan can I get a b16 and tranny installed for like 3k? I got the car with like 120k on it I've been nice to it regular oil changes stuf like that has new timing belt and all the gaskets are new. I just need more pop the motor I saw from this site had a b16 with a tranny with a lsd for like 2600 I know the b16 is sorta weak sauce but it will respond better to cheaper mods than the poor ls would and I would have fun with the shorter ratio tranny lol thanks again for the responses
Old May 23, 2007 | 01:44 PM
doood's Avatar
Default Re: (whatan00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_005200 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know, do you know? I am just saying as i believe many of the people in this form would say is its not worth the hassel. I means you are honest telling me that you would go ahead and invest in a motor that has 164k on it? I know honda motors are built tough but at some point even the most proper kept motor has to go sometime. Just my opinion tho. </TD></TR></TABLE>
if compression and leakdown numbers came back ok i would definitely boost it. as long as the maintenance is kept up with and the tune is good it wont grenade overnight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatan00b &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure the numbers the motor is pretty darn stout imho but a new motor sounds like a plan can I get a b16 and tranny installed for like 3k? I got the car with like 120k on it I've been nice to it regular oil changes stuf like that has new timing belt and all the gaskets are new. I just need more pop the motor I saw from this site had a b16 with a tranny with a lsd for like 2600 I know the b16 is sorta weak sauce but it will respond better to cheaper mods than the poor ls would and I would have fun with the shorter ratio tranny lol thanks again for the responses</TD></TR></TABLE>
do not downgrade to a b16 motor. go ahead with a b16 tranny though.
Old May 24, 2007 | 12:36 PM
whatan00b's Avatar
Default Re: (doood)
Would 3k be a big enough budget for this adventure
Old May 24, 2007 | 12:47 PM
VTECth1s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatan00b &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have a 92 ls with 164k miles motor and tranny in good shape. I have about 2500 I'd like to spend on it I've been considering a turbo but I don't know if I wanna deal with it also a lsvtec doesn't sound like a bad idea either. I'm only looking to make about 190hp something comparable to a new si my buddys is really nice to drive and I'd like mine to have that zip sorry about the giant run on sentence but I'm typing from a phone. Thnx in advance for suggestions or ideas timtim</TD></TR></TABLE>
Lots of miles on your motor already, whats the condition of it? was it serviced and maintained correctly? Have you done a compression and leak down test to determine what needs to be replaced. I'd suggest that you save up a bit more and rebuild the motor to do an all-motor ls build or even a ls-vtec if you have all the right sources and help, or just swap out the motor entirely for a newer and lower mileage motor, like a b16, gsr, or itr. Either way you go, save up some more benjamins and you'll be set.
Old May 24, 2007 | 10:05 PM
whatan00b's Avatar
Default Re: need suggestion (VTECth1s)
Well I haven't had a compression test run on it. I would say its in pretty goon condition doesn't burn oil and still has some good pull to it. It has a new timing belt and water pump new cam seals and head gasket. Oik changed every 3k all the little stuff taken care of. I'm kinda partial to just slappin a b16 in and just calling it a day and saving again and possbily turboing it instead. I'm gonna take it to the local speed shop and get a estimate in the next couple days ill post up the price lemme know if I'm getting a good deals
turbogenetic
Apr 12, 2009 08:26 AM
pooRmansss
Feb 22, 2009 09:39 AM
tylertocker
Jun 10, 2007 06:56 PM
Weapon X
Aug 5, 2006 07:18 AM
greddy13
Jan 27, 2006 02:54 PM
