Simple ECU question
Old May 21, 2007 | 06:17 AM
Spoogen_1's Avatar
Default Simple ECU question
If im running an Integra with a LS motor and b16 tranny which computer should I be running? SI or GSR or Other? I think the Si one but im not sure.
Old May 21, 2007 | 07:32 AM
pvt_awol's Avatar
Default Re: Simple ECU question (Spoogen_1)
neither. Keep the LS ecu. The ecu has nothing to do with your gear ratios.
If you change to one of those other ecu's, your check engine light will be on and the ecu will be in limp mode. There is no power to gain there. Plus your rev limit will be raised, and your LS won't be able to handle it if you over rev.
Old May 21, 2007 | 07:53 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: Simple ECU question (pvt_awol)
^^^what he said
Old May 23, 2007 | 08:59 PM
Spoogen_1's Avatar
Default Re: Simple ECU question (St Jimmy)
But at the moment I have an automatic. I would be swapping it to 5 spd. Should I get an LS 5spd ecu?
Old May 24, 2007 | 06:34 AM
St Jimmy's Avatar
* B A N N E D *
Yes
Old May 24, 2007 | 09:13 AM
deadline's Avatar
LS x30
Old May 24, 2007 | 09:24 AM
Spoogen_1's Avatar
Default Re: (deadline)
Cool thanks. Since I already have this post and I have search around for the list of parts I need for an auto/5spd swap lemme setup the list I have and I wanna know if im missing anything. thanks
1.Tranny w/ slave cylinder
2.ECU
3.Shift Linkage
4.Shifter
5. Master Cylinder
6.5spd Pedals
7.All the lines
8. Wiring (reverse lights ect. Start with clutch depressed ect)
9. All the interior plastic
10. 5spd tranny mounts
Heres the list of things that i heard I need but not really sure if I really do need it or not. I dont understand why I would need these things.
1. 5spd Distributer
2. 5spd manifold
Anyone wanna verify or let me know if I missed anything. Im sure I have.
Old May 24, 2007 | 10:19 AM
mmuller's Avatar
Mad Scientist
Default Re: (Spoogen_1)
distributor and manifold not needed, you can also just conver your ecu to manual. real easy
Old May 24, 2007 | 04:58 PM
Spoogen_1's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">distributor and manifold not needed, you can also just conver your ecu to manual. real easy</TD></TR></TABLE>
How?
Amed Irizarry
Mar 6, 2011 01:18 PM
phat teg dmk 98
Jul 24, 2004 09:03 PM
psycho_civic
Apr 26, 2004 02:16 PM
GSblueRacing
Aug 12, 2002 08:21 PM
