B20 Vtec
Old May 23, 2007 | 04:45 AM
g0tgot's Avatar
Default B20 Vtec
does anyone have a b20vtec setup? just looking for maintnence level...i heard b20's are HELL to maintain, and you might need a better clutch than a stock clutch because you get no traction.....is this true>?
Old May 23, 2007 | 06:33 AM
1.8L_allmotormilitia's Avatar
It's not hell to maintain it unless the block is built right like this! https://honda-tech.com/zerothread?id=1992114
Old May 23, 2007 | 09:29 AM
thegreat0ne's Avatar
Default Re: (1.8L_allmotormilitia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia &raquo;</TD></TR><TR><TD CLASS="quote">It's not hell to maintain it unless the block is built right like this! https://honda-tech.com/zerothread?id=1992114</TD></TR></TABLE>
so, b20vtec is hard to maintain if you build it right?
Old May 23, 2007 | 09:32 AM
Default Re: (thegreat0ne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegreat0ne &raquo;</TD></TR><TR><TD CLASS="quote">
so, b20vtec is hard to maintain if you build it right?</TD></TR></TABLE>
no. just change your oil on time and don't use trash oil and don't rev it to 15,000 rpm. Even though the link i showed you above is being built right i still wouldn't rev it past 8500 MAX RPM.
Old May 23, 2007 | 09:44 AM
b20quang's Avatar
roflmao, i think he's being sarcastic. Why would your car be hard to maintain if you build it right?
ABCVTEC's Avatar
Your power band probably drops at 8,500 anyway...
And thegreat0ne meant that you said it wrong You said B20V is hard to maintain if it's built right.
It's still going to be hard to maintain anyway. It's not a factory produced motor.. there are things you can definitely do to avoid common problems of mix matching heads and blocks but all-in-all you would have less problems with a B16/GSR/ITR motor.
Old May 23, 2007 | 10:09 AM
Default Re: (ABCVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABCVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Your power band probably drops at 8,500 anyway...
It's still going to be hard to maintain anyway. It's not a factory produced motor.. there are things you can definitely do to avoid common problems of mix matching heads and blocks but all-in-all you would have less problems with a B16/GSR/ITR motor.</TD></TR></TABLE>
yeah power band after 8500 isn't much since its also CTR cams.
Default Re: (b20quang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20quang &raquo;</TD></TR><TR><TD CLASS="quote">
roflmao, i think he's being sarcastic. Why would your car be hard to maintain if you build it right?</TD></TR></TABLE>
yeah i thought the same too thats why i put the smiley face haha.
Old May 24, 2007 | 04:59 AM
g0tgot's Avatar
from waht i understand there is also a high compression b20 and a low compression b20......something like a pr4 head and a diff head for that spec motor......i purchased a used motor from motorworld for about $775 with about 30,000 miles. was this a good deal? my motor is supposed to be a 1999 b20b with the high compression head......140hp and 150-160ft torque ......i think this motor isnt going to get much traction either....
Old May 24, 2007 | 10:29 AM
Korch94's Avatar
Default Re: (g0tgot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot &raquo;</TD></TR><TR><TD CLASS="quote">from waht i understand there is also a high compression b20 and a low compression b20......something like a pr4 head and a diff head for that spec motor......i purchased a used motor from motorworld for about $775 with about 30,000 miles. was this a good deal? my motor is supposed to be a 1999 b20b with the high compression head......140hp and 150-160ft torque ......i think this motor isnt going to get much traction either....</TD></TR></TABLE>
the heads shouldn't have any diff. the 2 types of b20's are the b20b and the b20z with the z having slightly higher compression
Old May 24, 2007 | 04:25 PM
doood's Avatar
been there done that
Default Re: (Korch94)
some jdm b20's came with the p8r head. it had 84mm combustion chambers and vtec sized intake valves. pretty good flowing head but not so easy to find.
Old May 25, 2007 | 08:08 AM
g0tgot's Avatar
that is the head that i have on the motor that i purchased, any thing special ?? from what i understand it has a butt load of torque
Coolero
16
Aug 5, 2024 09:22 PM
HondaTeKnology
Dec 20, 2007 10:17 AM
duyfash0
May 11, 2007 10:47 AM
my_little_beast
20
Dec 25, 2004 11:02 PM
duvinclunk
Jun 19, 2003 01:54 PM
