which sensor?
Old Apr 29, 2008 | 11:43 AM
daibloblanco's Avatar
Default which sensor?
i just bought a 94 integra and when it sits idle the engine revs a little (bout 1k-2k rpm) over and over and i think its just one of the sensors are bad, anybody know which sensor that would be?
Old Apr 29, 2008 | 12:22 PM
g2daturbo's Avatar
Default Re: which sensor? (daibloblanco)
check the iac idle air control valve...lots of posts about how to do this
Old Apr 29, 2008 | 12:30 PM
Default Re: which sensor? (g2daturbo)
the engine is a b18b1 does that matter?
Old Apr 29, 2008 | 03:55 PM
dc2much's Avatar
no it doesnt. i also would check for a vacuum leak
Old Apr 29, 2008 | 06:32 PM
Blahblah718293's Avatar
Default Re: which sensor? (dc2much)
definetly sounds like a vacuum leak
if you take a can of carb cleaner, spray a little slowly around all the vacuum lines, if you hear the engine change, the carb cleaner is getting sucked in the vacuum leak and evening out the mixture, and there you have your leak.
you may also wanna clean off your iac.
poormans_typer69
Oct 30, 2007 05:10 PM
Dakota11
Dec 20, 2005 05:43 PM
barry11j
Mar 9, 2005 07:11 AM
Hcivic88
Oct 17, 2002 04:40 PM
chirp2hrd
19
Sep 19, 2002 09:24 PM
