91 integra fuel problem
CEL # 16 fuel injector 43# fuel supply system both on
91 integra gs b18a1 manaul tranny symptom: i tend to smell fuel , and the car recently had a tune up (NGK plugs n wires), cylinder balance test showed that every cylinder is contributing when i pulled a plug wire one at a time, compression is good. i think that maybe the injector o rings are old ( smell ). I guess the only thing i can do is replace the injecots and o rings! i have a fuel rail off an 88 integra auto b18a? are they the same size? the harnesses and the clips are!
By replacing the injectors if that is the problem do you think that will fix both codes? Thinking about changing the fuel filter too!
any help of opinion greatly appreciated
