CEL code P1259
Old Apr 29, 2008 | 01:57 PM
PnoyJeff's Avatar
Default CEL code P1259
i threw a check engine code today cruising on the high way
P1259 Manufacturer Control Fuel Air Metering
did a search...only saw civics/accords threads about vtec malfunction.
what should i begin checking? i was thinking o2 sensor at first but i think thats a different code cus i had that before. but im not sure
so i need some help where to get started looking. and if this is safe to drive on
car is a 2000 integra gsr. only mods are i/h/e. oil is fine. car seems to run fine. dont know if vtec is working cus i didnt think i should be heavy footing around with a cel on
thanks
Old Apr 29, 2008 | 02:00 PM
Jimmy's Avatar
Global Moderator
I'm not to sure on the code to be honest.. If the car seems fine
Try resetting the ecu by either pulling negative battery cable or pulling the ecu fuse and see if the code will go away.
Gixxerboy02
Apr 30, 2006 01:16 PM
EKtypeRhaTcH
Jan 13, 2005 04:53 AM
arw321
Jan 22, 2004 08:33 AM
S2KILLA
Sep 17, 2003 05:56 PM
DBallz
Aug 29, 2003 05:56 PM
