oil in my first spark plug
Old Apr 29, 2008 | 09:56 AM
Dj Skidz7's Avatar
Default oil in my first spark plug
hey so i was taking my spark plugs apart and saw that i had oil in my first spark plug like once i take out the spark plug wire and was wondering what that was and how to fix it if anyone out there knows that would be great and if thats bad for my motor thanks
Old Apr 29, 2008 | 10:31 AM
Jimmy's Avatar
Global Moderator
Most likely your valve cover spark plug tube seals..
And oil in your cylinder/ on your plug can foul out your plug.
Your gonna need to pull the valve cover off.. replace the gaskets and the valve cover gasket and put a new plug in.
Old Apr 29, 2008 | 11:16 AM
lynchjdm's Avatar
Default Re: (Jimmy)
i replaced the seals on my ls and continued to get that problem...found out that i had a broken valve cover bolt and the seal wasn't sealing correctly. i suggest you go buy the seal kit from autozone/napa/etc. and just make sure all your bolts are on the valve cover
t0kyoStatus
Nov 26, 2008 07:05 PM
turboteg90
Oct 9, 2007 04:53 PM
sahtt
Aug 4, 2007 01:59 PM
Red_Si
Oct 26, 2006 10:48 AM
frozenb
Mar 31, 2005 09:12 PM
