Brake problem
Old Apr 26, 2008 | 05:47 AM
hondaboy4life's Avatar
Default Brake problem
Have been having a recent brake problem and before i go buying the parts i think i need i wanted to go to you guys to see if you guys knew what was up. My car is a '94 ls. Heres what happens. When i am sitting at a light applying the brakes, i can feel the pedal slowly go down to the floor. Also, when im braking the pedal goes in further than normal. Also when applying the brakes i can feel the rear rubbing like they arn't fully engaging. Also a while ago my brake fluid was down far enough to where the brake light came on. I refilled it and it takes a while to go down/havnt had the same fluid loss problem yet. I looked briefly at the firewall but didnt see any fluid. I am about ready to buy a booster and M/C from a gsr unless you guys tell me otherwise. I assume a gsr setup will work...?
Old Apr 26, 2008 | 07:18 AM
hatchling37's Avatar
Default Re: Brake problem (hondaboy4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboy4life &raquo;</TD></TR><TR><TD CLASS="quote">I assume a gsr setup will work...?</TD></TR></TABLE>
Yes it will work wonderfully, as it's the exact same one you have in there now. It sounds like your master is ****, but to make sure it's not the booster, pump up the pedal with the car off, and then hold the pedal down and start it up. The pedal should give a little. If it doesn't dip any, you've got a booster problem.
Look thoroughly around the master and look inside under the dash. Make sure it's not leaking there. Then check all your hose ends and fittings. It's imperative that you find where it's leaking, as the fluid won't just disappear- it's a closed system.
As for your haggard pedal engagement, it's very likely you've got air in there somewhere. Bleed out the whole car (once you find the leak and repair it) RR, LF, LR, RF. That should take car of it.
Old Apr 26, 2008 | 10:43 AM
Jimmy's Avatar
Global Moderator
Yes GSR will work 100%
I even think the GSR is better than the RS,GS,LS.. As these are 15/16'ths mc.
Old Apr 26, 2008 | 11:02 AM
94 IntegraLS's Avatar
Default Re: (Jimmy)
let me know how you make out because I have similar problems but its only when i restart my car and I also had to refil my brake fluid twice but I cant seem to find a leak either.
Techna600f4i
Jun 11, 2005 05:53 PM
aeongap
Dec 5, 2004 02:40 PM
donniebrasco
Oct 5, 2004 07:43 AM
SoldMyEM1
Dec 25, 2003 06:31 PM
paeaknoy
May 21, 2003 09:32 PM
