Integra front O2 sensor replacement
hi guys, i wanna replace my primary o2 sensor myself. do you know how hard it could be? does anyone has guide or pictures how to do it yourself/?
i heard you will get better milage if you replace your o2 sensor. is it true?
thanks in advance..
thanks in advance..
Yes if your O2 sensor is old/has lots of miles on it you could see a nice increase in gas mileage.
What year car is this on?
Procedure for replaceing the o2 would be..
Jack the car up.. Use a jack stand.. at the bottom of the exhaust manifold right before the catalytic converter.. Loosen the O2 sensor and unplug the harness.. and replace.
If you have problems removing the O2 i suggest using PB blaster or wd40.
theres probably 4-5 threads telling you yes. you will improve gas mileage.
its pretty easy, but you need to get under your car.
from my understanding, it is located on your cat, closest to your exhaust manifold.
you will have to unbolt your cat from your exhaust manifold, and pull your cat down to see the o2 sensor and bung. there is a special tool for your wrench to take it out. looking up a picture of the 02 sensor, you will see what im talking about.
replace and reset your ecu and youre done!
search function and reading is key...
thanks guys.. what is with replacing and resetting your ECU i m kinna scared to do that..
i donno how to even do that. i will try to do it myself
its going on my 95 integra.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZE12O »</TD></TR><TR><TD CLASS="quote">theres probably 4-5 threads telling you yes. you will improve gas mileage.
to reset your ecu, i believe the easiest way is to disconnect your battery, and leave it off for.... five minutes. i dont know how long it takes for electricity to cycle out of the electrical system. dont worry it will not effect anything except your clock and your radio settings etc...
good luck
good luck
p.b.k
Jun 10, 2010 06:42 PM
janek
Dec 4, 2008 06:36 PM
