CKF sensor
Old Apr 29, 2008 | 08:34 PM
trapperj86's Avatar
Default CKF sensor
Hi I have a jdm gsr in my 98 gsr.From what i have read the CKF sensor is in the dizzy on the jdm motor?So I do not have the wire hocked up so i have a check engine light.I read this http://technet.ff-squad.com/ckftrick.htm and this says that if it has NO CKF sensor.If I do this will everything work right and will it get rid of my check engine light?
Thanks for the help
Old Apr 30, 2008 | 07:48 PM
trapperj86's Avatar
Default Re: CKF sensor (trapperj86)
Im going to do this thursday anyone have any ideas i just dont want to fry my ECU or anything.
thanks
Old May 1, 2008 | 01:06 PM
Jimmy's Avatar
Global Moderator
It should be the same with usdm/jdm..i believe, but on the older jdm engines don't have CFK sensors.. pull the crank pulley off and see..
read this thread.. it might help a little.
https://honda-tech.com/zerothread?id=2156894
Old May 1, 2008 | 01:54 PM
trapperj86's Avatar
Default Re: (Jimmy)
yea there is no CKF by the crank pulley.So does that mean there as not one.I was told it was in the dizzy,thats why im confused.But if there is not I will be safe doing the wiring in the link to get rid of of the CEL?
rig9896
May 22, 2013 04:29 AM
roycivic92
Feb 5, 2012 09:33 PM
Unphzd
Nov 23, 2010 01:47 PM
tyflip2
Dec 5, 2003 08:32 AM
