DA...need help....please look
Old Apr 28, 2008 | 07:46 AM
kaspa35's Avatar
Default DA...need help....please look
I was driving my 1990 ls...and the car just shut off and the check engine light came on....the car was still roaling (going about 40mph) i just started the car and it started back up...and now sometimes when im sitting stopped at a light or something the rpms will drop like its gonna die..but if i give it gas it seems to be ok...any thoughts...maybe fuel filter or fuel pump?.... ....also once when i tried to get on it a little it cut off again...i have only tried that once...
Old Apr 28, 2008 | 08:19 AM
lsneo's Avatar
check the main fuel relay.
Old Apr 28, 2008 | 11:07 AM
super jdm yo's Avatar
Default Re: (lsneo)
yeah i could be your fuel filter or main rely. also check your grounds.
Old Apr 28, 2008 | 12:26 PM
red01teg's Avatar
Default Re: (super jdm yo)
1. check grounds
2. perhaps main relay
3. worse case scenario distributor going bad
good luck
Old Apr 28, 2008 | 01:47 PM
bruceda9's Avatar
sounds like the distributor.
Old Apr 28, 2008 | 02:02 PM
kaspa35's Avatar
Default Re: (red01teg)
im pretty new to the teg scene...can some one tell me where and hot to check the main relay....dizzy....and grounds...thanks
Old Apr 28, 2008 | 03:02 PM
nicks-eg6's Avatar
Default Re: (kaspa35)
your spark plug wires are connected to your dizzy.
Old Apr 28, 2008 | 03:16 PM
kaspa35's Avatar
Default Re: (nicks-eg6)
i know that??..............anyone else
Old Apr 30, 2008 | 08:49 AM
kaspa35's Avatar
bump...still have this problem...update: the car sat for two days..i got out to start it and it starts right up..../????....it seems like when i accelerate kind of fast and the rpms get to like 4k it goes off and check engine light comes on...please help
Old Apr 30, 2008 | 09:56 AM
Danziver's Avatar
Default Re: (bruceda9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceda9 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the distributor. </TD></TR></TABLE>
x2
I had a similar problem and a new distributor was the fix.
Old Apr 30, 2008 | 10:00 AM
chamoru's Avatar
Default Re: DA...need help....please look (kaspa35)
check if your ecu is throwing any codes. pull passenger carpet back till you see your ecu, turn the key 1 click i believe and see how many times the red light flashes. just a little help.
Old Apr 30, 2008 | 03:03 PM
kaspa35's Avatar
Default Re: DA...need help....please look (chamoru)
thanks ill try that....will that tell me if my dizzy is bad? and if not how can i check it....and what would be a good price to pay for a new one..thanks guys
Old Apr 30, 2008 | 03:05 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaspa35 &raquo;</TD></TR><TR><TD CLASS="quote">thanks ill try that....will that tell me if my dizzy is bad? and if not how can i check it....and what would be a good price to pay for a new one..thanks guys</TD></TR></TABLE>
Pull the codes.. and let us know what code it is throwing then we can go from there.
Rick1t
27
Aug 16, 2013 06:59 AM
BPDA77
Apr 3, 2013 04:38 PM
95PreludeNAed
Jan 10, 2012 04:09 PM
b17itr
Feb 7, 2011 07:45 PM
TheTealHatch
23
Oct 14, 2008 12:01 PM
