Tranny Problems?
Old Apr 30, 2008 | 03:47 PM
Royal_C!ty's Avatar
Default Tranny Problems?
Hey,
just did a gsr tranny swap on my ls teg, I started the car to test out the new trans and when the car starts a grinding noise occurs when trying to put the car into gear ( i'm assuming it to be a blown tranny.) The drive axle (pass. side) keeps rotating and all but the weird thing which i'm not sure if this maybe an exact tip off to whats wrong but when the clutch is disengaged and put into gear the speedometer starts increasing as if it's going somewhere...
so H-t what's the verdict? blown tranny? possible axle problems? anything else you can think of let me know, definitely open to suggestions!!!
thanks in advance!
- justin
Modified by eg8kid at 5:12 PM 4/30/2008
Old Apr 30, 2008 | 03:52 PM
Jimmy's Avatar
Global Moderator
Does the tranny go into ANY gear?
Are you 100% sure both axles are secured in the tranny?
Old Apr 30, 2008 | 03:56 PM
Royal_C!ty's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Does the tranny go into ANY gear?
Are you 100% sure both axles are secured in the tranny?</TD></TR></TABLE>
the tranny's going in to gear and all as for the axles they are popped into place...
any other ideas?
Old Apr 30, 2008 | 04:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Tranny Problems? (eg8kid)
Is there any noise once the car is in gear? With the speedometer indicating speed when in gear, the differential must be spinning and you have a loose axle or blown differential.
Old Apr 30, 2008 | 09:29 PM
Royal_C!ty's Avatar
Default Re: Tranny Problems? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Is there any noise once the car is in gear? With the speedometer indicating speed when in gear, the differential must be spinning and you have a loose axle or blown differential.</TD></TR></TABLE>
turned out to be the outer boot of the pass. halfshaft was broken, replaced the axle and voila!
now i'm rolling
2wheelhunter
Dec 1, 2006 09:04 PM
gsrHB
Sep 20, 2005 07:50 PM
HXvtec
Oct 14, 2004 11:27 AM
crazy eyez killa
Nov 26, 2003 05:57 PM
