trans and break lights problem
HT people,can pls some help me. I hava a 1990 db1. The problem is my break lights and rear lights is not working then suddenly the transmision is stock to Park. I can only shift the trans if I put the Shift lever key lock. then I can put it to R or D. the weird thing is I replaced the fuse for the break and rear lights then the transmision shifts properly. after a few minuetes the break lights went out again so Im assuming something is grounded in the wiring because the fuse is burn out. then I cant move the shift lever again. is it connected to the break and rear lights?
